0 Members and 1 Guest are viewing this topic. Read 78587 times.
I ran both SPDIF (rca coax) and AES/EBU (xlr) inputs on the Zodiac Plus, and although they sounded a bit better than the USB input initially (using my Weiss DAC2 as firewire to digital output interface) after the pre-requisite 200+ hours of break in the USB (mini and all) input was just as good, if not better, and that Weiss interface is no slouch. I used a Wireworld Ultraviolet USB cable with standard connections, and then attached a mini-b adapter I got through Lee (cryoparts). Sounded fantastic.
Thanks for the info. Ted, that is interesting and encouraging. Sounds like Antelope has their asynchronous USB port dialed in. I just cringe at the idea of needing to insert a usb-spdif converter pre-DAC.Any comments on listening to the balanced xlr vs. single ended analog outputs?ThanksKenreau
Srajan,Thanks for that. I heard about the OS panel, too.Yes, my email to you mentioned 200 hours, and I think 300 is more accurate. I can't honestly say I heard anything beyond 300 hours, and agree if that is the case (often is with Dan Wright's stuff, for example..my KWA150 monoblocks settled in around 600 hours..those are big caps) then they need to get you a pre-owned certified model for review.
I currently have it setup like this:Computer -> GoldX firewire cable 4-6pin w/adapter -> Saffire Pro 24 DSP firewire interface -> wireworld spdif -> Zodiac+And the sound is fantastic. I will be comparing to straight usb soon hopefully. FYI, no word yet on when my upgraded power supply will ship from Welborne Labs. edit: Welborne Labs power supply has shipped.
Gabriel, This was covered pretty well in Srajan's review, you might want to check that first and then if you have questions that you have that aren't answered after reading that, post back here...
