0 Members and 1 Guest are viewing this topic. Read 90438 times.
Now you tell me.I figured it out this morning spending a couple hours going through the various DCB1 threads on diyaudio. Christ, there has got to be a better way of organizing information on that site.Didn't want to guess what I'd be missing so I ordered the parts for the hot rod build.
Wushuliu,There is something a little confusing about this board. Look dead center where the 10 LED's are installed (5 LED's per rail). I remember you saying that the flat back corresponds with the cathode or shorter lead of the LED. I also noticed that the LED's have a square hole side and a circular hole side. You'll see that the square hole for the 3 LED/rail section corresponds with the cathode, but this doesn't seem to be true for the 5 LED/rail side. So is the pictograph of the LED accurate or is it the hole shape that is accurate to designate which way the LED's should be mounted?Anand.
Just an FYI that I forgot to mention: the dcb1 boards can also be used just as power supplies for other low current devices. Just ignore the audio part of the board and take the power straight from the +/-V and G shown in the pics...For instance, the Hagerman Bugle phono pre... Probably cheaper (and just as easy if not easier) than the Bugle PS.
Wanted to show off my now completed DC B1. ... I use a powered sub....
