0 Members and 1 Guest are viewing this topic. Read 29582 times.
Interesting thread, and sorry to miss this while I was away on vacation for a few days. I don't have too much to add at this late date, but I encourage people to set up a controlled test if possible, to fairly compare absorption versus diffusion. I haven't done that for the ceiling reflection points in my living room HT because it's a pain with my high angled ceiling. But I did do a carefully controlled test at the side-walls, and absorption won there handily.I assume that speakers having a narrow dispersion pattern are affected less by either absorption or diffusion. And of course speaker dispersion varies both horizontally and vertically. Speakers that don't send very much sound upward probably don't need anything on the ceiling.--Ethan
I don't have any measurable data supporting this assertion, but I am guessing that my speakers (Vandy 5A's) would benefit from something on the ceiling. At the last few shows, Richard Vandersteen brought room treatments for all the first reflection points and used diffusion on the ceiling.George
George, you could probably do a test, since you have diffusion already behind you. Take those diffusive elements out of the room and listen for a while. Then put one of the diffusive elements "on" the ceiling and see what the results are. The hardest part will be figuring out how to get the diffusive elements up there temporarily.I don't have any diffusive elements to test, and my room is still under construction (drywall in, but still needs to be painted and the wainscoting put in).
But is it possible that other rooms can give different test result?
Ethan, care to let me borrow some diffusers?
Not sure if you have seen the size of the Realtraps Diffusors, but they are quite big (24x48x6 and 26 lbs) and definitely not something to just take down from the current location and temporarily relocate them to the ceiling. Here is a picture of them in my room:George
That's not out of the question, and you're always welcome to visit me here to compare absorption versus diffusion. I just got a new huge (159 inches) video screen and it's awesome.--Ethan
Uh-oh. You've gotten sucked into the HT thing Ethan. It's an even bigger money hole than audio sometimes
Sure! I'm very open about explaining that my few tests were done in small rooms. One was my living room which is 25 feet front to back by 16 feet wide. The other was a smaller room, 17 feet long by 11.5 wide. The difference was so obvious, with absorption winning by a landslide, I'm always surprised when people say they prefer diffusion. But maybe their room is wider, and of course personal taste is a factor.--Ethan
I've had a "video" setup for years. I started with a 65-inch Mitsubishi RPTV many years ago, which I still have (behind the screen) that still works great for watching TV and older low-res DVDs. Then a year ago I got a 110-inch screen and Mitsubishi projector and Blu-ray player. I was sure 110 inches would be huge! Alas, for an entire year Elli and I fantasized about a much larger screen. So a month ago I sold the 110" screen and got this monster that's 12 feet wide:Our couch is ten feet from the screen, so it's like being at an IMAX theater. "Immersive" is an understatement. --Ethan
For a man of your caliper....
I personally like combination absorber / diffuser products at the first sidewall reflection points. Either RPG BAD, BAD Arc, or one of the similar products. A similar effect can also be realized through interleaving pieces of absorption with the reflective wall surface by using 6" thick strips of absorber or small squares.
