0 Members and 1 Guest are viewing this topic. Read 29640 times.
I recognize that diagram. George
If your tweet/mid is the same height as your ear, ceiling first reflection point should be half the distance to the speaker.should the "baffles" of a diffuser be perpendicular to your line of sight or parallel?
LOL. Not hardly Pete. Not my game.My personal preference is absorption for lower ceilings, diffusion for higher ceilings with the caveat that it's still speaker and room dependent. Diffusion on the ceiling can also help when you have hard floor surfaces and not just at reflection points. If you want the illusion of more height (assuming a non-dipole/bipole speaker) is to use diffusion on other walls of the room besides the front and orient the fins horizontally so you induce more later reflections coming from the ceiling to trick the ear/brain into thinking the ceiling is higher.The biggest problem with diffusion in lower ceilings is purely a matter of headroom. To get a proper diffuser to function down to say around 500Hz, you're looking at something that's around 6" thick. That's a tough sell to a lot of people who have 8' or less ceiling height (especially if you're as tall as Pete is!)Bryan
Pete,you got a pic of those diffusers?....your gallery was a little intimidating to search did you buy or diy?
Pete, have you done a rta of your room? It would be interesting to see the plots of your favorite absorption era and plots as you add more diffusion.
Hey..newbie question here..Big Red doesn't that area (shown directly under the number 5) make a kind of echo chamber, not the right words but isn't the space in there conducive to slap back echo of some sort..I'm curious as I initially thought diffusion was to totally break up the sound waves, I guess I'm thinking standing waves in that section....
Can one of our acoustics gurus comment on ceiling diffusion? Does the the type of speaker impact its effectiveness?
Interesting thread, and sorry to miss this while I was away on vacation for a few days. I don't have too much to add at this late date, but I encourage people to set up a controlled test if possible, to fairly compare absorption versus diffusion. I haven't done that for the ceiling reflection points in my living room HT because it's a pain with my high angled ceiling. But I did do a carefully controlled test at the side-walls, and absorption won there handily.I assume that speakers having a narrow dispersion pattern are affected less by either absorption or diffusion. And of course speaker dispersion varies both horizontally and vertically. Speakers that don't send very much sound upward probably don't need anything on the ceiling.--Ethan
Hello Ethan,I don't know how you controlled your experiment but I am sure you used good empirical method for your test and that your result is valid. But is it possible that other rooms can give different test result? My personal observation (without measurement) is that not much changed in terms of overall sound stage depth or width when I went from your Micro panels to SRL diffusers on the side walls. The initial placement of a diffuser on the back wall paid huge dividend in terms of establishing a solid sound stage with big depth. The addition on the first reflection points on the side wall did not add anything. The difference is in the overall sound of music in the room. I went with diffuser on the side wall to reduce refractive interference without sapping the overall tonality. I think I get better decay characteristics with diffusers. This may have something to do with the fact that I like the sound of acoustic instruments (including voice) in acoustically lively venues. I don't like acoustic music in outdoor venues as much. I like tones to decay "naturally" and too much absorption, to me, deadens the lingering harmonics too quickly. I am only saying this after I have filled the room with 10 of your absorbers and 4 from GIK. I have also put acoustic tiles (absorption) on the drop ceiling (doubled on the ceiling reflection points) and stuffed the corners and edges above the ceiling with fiberglass batting.
