Why does my turntable hum? Hopefully, we can get down to some real causes.......
0 Members and 1 Guest are viewing this topic. Read 9149 times.
Wayner
  • Audio by Van Alstine Industry Participant
Perhaps this should be in the vinyl circle, but that would restrict some  of my comments (pro AVA stuff), so it is better suited to Frank's  circle. Others from the vinyl circle and other ilks may join, but  understand you are in an owner's thread.
 To start, let me say that in the last month or so, with my newly created  turntable ARCom, I have never enjoyed vinyl with such excitement.  Perhaps it's the synergy between the components, like the Insight+ EC  preamp with the optional phono board, or the Ultravalve amplifier or  even the Dynaco modded A25XL's, the fact is, there is some superb vinyl  being played at this house.
 There is an indescribable thrill listening to vinyl, and have the end of  the song fade to black. Of course, a clean record helps, but so does a  clean signal. When you have everything right, the system lets you know  as it vanishes, letting the music be the center of attention, rather  then the equipment.
 One of those evil little mood destroyers is that dreaded hummmmm, that  every vinyl guy/gal fears. It ruins the music, and leaves the listener  watching TV. Where does the hum come from? Is there more then once source of hum? Can I have more then one cause?
 I hope some of you jump in with some of your stories. Hopefully you can  post a cause and a solution, and if you have a problem, perhaps the  minds here can help you find a solution.
 As I was finishing ARCom, I had a slight hum problem. The hum wasn't  really in the normal playing level, but, like most of you, I jack the  volume up when I'm not playing a record, just to see what the background  is like. Well at about 11:30 position, the hum would start to show up.  It took me 2 days to figure out that it was the ungrounded mounting base  for my AR ES-1 tonearm that was the cause.
 Lesson learned. If it's a metal part connected to the tonearm in any way  shape or form, it's an antenna element. Unless it's grounded, it's a  case for being a hum producer. Sure the body of the tonearm is grounded,  but the ground thru the pivot is weak. It's a moving pivot that doesn't  sometimes offer the best path for grounding, so the enemy was the metal  base. An attachment wire to the ground screw was the fix.
 I'm sure there are other stories out there.
 Wayner
rlee8394
Wayner,
Because it doesn't know the words!  :lol:
Ron
P.S. I couldn't resist. That's one of Frank's comebacks!
Wayner
I thought it would take a couple of posts for this one to come up, but Ron wins! You beat Frank to the punch. Sweet.
Wayner :D
kgturner
I've been lucky thus far as I've never had a hum problem with my turntable. I used to have a real low level hum (even before adding a table) which I assumed was due to the DHT in my Supratek preamp. It didn't interfere with the music and I just kinda figured it would always be there. I then picked up a BPT 3.5 which has now made the hum almost non-existent. I say almost because I really have to crank it up, put my ear next to the speaker, and listen for the hum. I bet whenever I sell my house, my next place will probably have all manner of ground loops and hum problems just to punish me for all the years of silence I've enjoyed.
Kevin T
Berndt
I learned on the Galibier forum that those guys have a ground harness. Tonearm mount, bearing, chassis, etc. The harness has bullet connectors so you can try grounding different parts together. I've not had much of an issue until I started using a step up transformer now the rig got a touch more finnicky.
r1seals
Wayner I have an old Pro-ject 1.2 that I have a problem with Hum when I turn my omegastar (pat 5) up to 11:30  do you think adding a wire to the base of the tonearm would help this? the cart I'm using is audio-technica ML a
 Ps wayner Just love your new turntable and would like to build one like it.
Wayner
Are you using the AT440MLa? There was a recall on these cartridges because they had a shielding problem and the cartridges hummed like no tomorrow. If you bought yours about a year and 1/2 ago, it might be a bad one. It certainly is not the fault of the AVA preamp or it's phono board.
Thanks for the comments on ARCom. It was a very successful project and I want to build another one based on the RB300 tonearm, using the same platter, bearing, but need to go with a different motor.
Wayner :D
avahifi
Install shorting RCA plugs into the phono inputs of your preamp and carefully crank up the volume and see how the noise level compares to when the TT is connected.
This will give you an idea as to how much noise is originating in the preamp and how much from the TT system.
Note that several years ago we did make a running change in the grounding of our solid state phono boards that really helped reduce residual hum levels. The ground wire (black wire running to the power supply board ground) should be connected near the bottom middle of the phono board, not near the top.  Check this out please on your unit.
Frank Van Alstine
r1seals
Wayner :D
Yea Wayner It is a 440 ML a don't know why I didn't put that in the post, I'll check my records  and see when I bought it    But with that being said It doesn't hum in  My AVA T-7 pre-amp.
r1seals
Frank Van Alstine
 Ok Frank will do  and thanks
Wayner
r1seals,
If you have a volt/ohm meter, see if you get continuity from the tonearm base to the turntable ground. If not, that could be the source of the hum. Care must be taken when attaching an additional ground as it really should be done in the "star" configuration, as all ground attachments end up in one point, rather then a series jump from one part to another.
The AT sounds like it is OK, because it would hum with every phono input on any preamp.
Wayner
r1seals
Frank Van Alstine
Frank I did remove the cover and the black wire is at the bottom  like you said so guess that was done last time it was with you. I tried to send a picture with no luck. oh well I'll try later.
 I don't have any shorting RCA plugs so didn't do that is there something else I can use?
r1seals
r1seals,
Wayner
 Ok wayner I will do that to we have a rain day here so I will get to that today  thanks
Russ
JuanR
I have a technics 1200, suddenly got a high hum  when I turn the pre to mc even with the tt off.
Wayner
Remove your headshell and clean the contacts on the headshell and the arm. This is the first place I would start. Use some rubbing alcohol if you have nothing else like Caig's De-oxit 5 or in a pinch, a pencil erasure works good too.
I have also noticed that I can induce hum into the SL1200 by over-tightening the headshell nut. Not sure what's going on, but make it snug, not monkey wrenched on.
Wayner
JuanR
I did clean the contacts, still with the hum, even disconecting from wall, the only way is disconecting from the preamp. any advise?
johzel
Any chance you have other things on the line like a dimmer switch?  I read this with interest - I had a right channel hum in my phono line the other day and couldn't figure it out - changed the interconnects and it went away.  Wished I knew why . . .
Wayner
OK, next take your headshell off and rotate each clip on the cartridge pins, not physically moving them from one pin to another, but rather just moving them on the existing pin to scrape away any film that may have collected, especially the right ground (green wire). Lots of cartridge bodies use this pin to ground the cartridge body.
By the way, with the hum, do both channels still work?
JuanR
I did remove the headshell, the ac from the outlet and still with the hum,I can not change the IC from the TT. and yes both channels work well.
Wayner
Well, did your ground wire from the TT to the preamp get loose or fall off?
Wayner
