0 Members and 1 Guest are viewing this topic. Read 49105 times.
Get one and try it out - they are dirt cheap.
This one i used. One of the cheapest and best i know.http://cgi.ebay.nl/DIY-2x25W-Class-T-Amp-TRIPATHS-TA2021B-KIT-BAUSATZ-/230509579789?cmd=ViewItem&pt=LH_DefaultDomain_77&hash=item35ab710e0d#ht_3560wt_1139http://www.art0.de/
BTW, the poster of the link I provided is none other than Thorsten of AMR:http://www.amr-audio.co.uk/html/cd_individual.htmlI like his CDP using the TDA1451.
Hi You should really try to maintain the blind testing as it looks like the designers of 2 of the DAC's will be present. Brian
The problem is, we can't have both, using 44.1 / 16 format, it's either one, the other or a combination of both. It looks like we have to make our own choices based on our personal preferences as there is no perfect way to go.
Yesterday spend all day in John Brows lab to update my 1541DAC with his the latest tweaks. We talked about dac technics and there main differences in sound perception. He just posted a short explanation in another forum. But it might be interesting for readers here:"NOS vs OSUnfiltered NOS offers highest accuracy in the time domain and poorest in the frequency domain.Filtered NOS offers reasonable accuracy in both time and frequency domain.OS offers highest accuracy in the frequency domain and poorest in the time domain.Linear interpolation (multiple DAC chips in parallel fed by delayed I2S signals) works excellent at lower frequencies, but distorts higher frequencies causing early trebles roll-off among other things. It can work very well in combination with a digital brickwall filter like used by Cambridge Audio in their 4 x TDA1541A CD player.The question would be what's most important for realistic sound reproduction, highest precision in the time domain or highest precision in the frequency domain. Based on many years of experimenting and listening to equipment designed by other developers it seems that accuracy in the time domain is much more important for achieving most realistic sound reproduction than we realize. This is the reason why I choose unfiltered NOS. Compromise I have to make is reduced accuracy in the frequency domain.The problem is, we can't have both, using 44.1 / 16 format, it's either one, the other or a combination of both. It looks like we have to make our own choices based on our personal preferences as there is no perfect way to go.We also have to realize that sound quality is determined by audio component matching. Connecting some random equipment together is very likely to cause mismatches and resulting sound quality degradation. It is also very important to understand specific audio component properties in order to achieve optimal matching.Example, unfiltered NOS won't work optimally with class-D or comparable switch-mode power amps as frequency spectra of both DAC and amplifier will inter-modulate."
Interesting. I wonder how up-sampling to 192/24 using programs like J River would change things - would you get the best of both worlds with a NOS then?
As far that i know there are no DAC chips who are capable to do 192/24 NOS DA converting.
There is a long discussion on his topic over on HeadFI.com forum titled NOS DAC -marketing bs where Dan Lavry goes into basic sampling theory that governs DAC and ADC operation. It is worth a read for anyone who has an interest in the technical side of the NOS/OS discussion. I can also recommend National Semiconductors Application Notes 236 and 237 as a basic primer.
The PCM1704 can and is in fact done in the Overdrive DAC:http://www.empiricalaudio.com/products/overdrive-dacThanksBill
Look in the datasheet. Its maximum 48 khz/16 bit. It is a delta sigma DAC with oversampling digital filter. Not really a pure NOS approach i.m.h.o.
I did - its a 24 bit R-2R ladder type DAC that can handle up to 768 khz - it does 192/24 NOS in a doodle:http://focus.ti.com/lit/ds/symlink/pcm1704.pdfThanksBill
The datasheet says: FEATURES ● SAMPLING FREQUENCY (fS): 16kHz to 96kHz ● 8X OVERSAMPLING AT 96kHzFurther:Digital data words are read into the PCM1704 at eight times the standard DVD audio sampling frequency of 96kHz (e.g., 8 x 96kHz = 768kHz) to create a sinewave output of 1100Hz. Further:The output of the I/V converter is then connected to a 40kHz, 3rd-order GIC low-pass filter. The filter output is then passed on to a programmable gain amplifier to provide gain for low-level test signals before being fed into an analog distortion analyzer.
I have zero idea why you are arguing about this. Companies have been selling pcm1704 NOS DAC's for yonks and DIY designs aboud.
