0 Members and 1 Guest are viewing this topic. Read 18256 times.
LM...if you've heard the older AKSA models and have some memory of them then it'd be nice to add that into your observations too
Lyn,Dead right. That's how I see it too. But the amp had a mid range and particularly a top end magic which was terrific on rock music, and this was the trademark sound which I've tried to capture ever since. However, only the NAKSA to this point has been more than a match, though the LF and Sorayas are very, very good, slightly to the right of center, more a sound leaning towards accuracy and soudfield deptHugh
For any that might wish to know where I think the new NAKSA 100 fits in the scale. I had the chance to listen to the NAKSA 100 at Hugh's this morning with some music that was quite familiar to me. What's more, Hugh swapped between it and the 09 Soraya, with which I am extremely well versed, a few times so I had a good reference point. I understand that 100 was pretty close to the production version though not the final power supply nor set in a case. As I said in the NAKSA thread, it has the same lovely 'SET like' tonality, solid base and rich mids of the NAKSA 70 but with greater overall drive and snap. It also has subtly increased refinement and treble extension; cymbals for example have a little more presence than with the 70. Not a lot but it's there. Optimising the power supply and encasing it won't do any harm to its final sound either though it's a very enjoyable and musical amp as is IMHO.So where on the scale do I hear the NAKSA 100 compared to the NAKSA 70? As with the 70, I see the 100 clearly on the left of middle with its warmth, musicality and engagement. However, its greater grunt and the slightly expanded treble moves it a bit closer to the Maya and Soraya overall. It really does catch your attention and demands you to listen, enjoy and get involved. It still reminds me of a tube amp tonally though the base and grunt are very much SS characteristics. Not quite as incisive as the Maya or Soraya perhaps but a superb toe tapping musical performance that no one could fail to like and amazing value.
Hi Ray,No, these were the standard version, not upgraded power supply caps.Prices:NAKSA 100 built/tested modules: $USD1420Soraya CB205 (100W//8R) plug 'n play: $USD4800Maya CB280 (150W//8R) plug 'n play: $USD6400At present, the AUD is almost lineball with the USD.Thanks for the inquiry.Hugh
One thing I have noticed and I have to commend you if this is true is that all three of your Amplifiers sound different. "yeah, so, what's your point?" you ask. The differences are enough that each model can stand on its own merits. So as a manufacturer they might have some similarities, but your Naksa doesn't sound worse than the Maya. Now in times past, you might have manufacturers that made equipment that the flagship would sound the best, and the others in the line didn't sound as good. I hope this makes sense. Now, I don't know if that was your goal or not, but from what I read you did it. I would think logically, that the Maya almost three times as much as the Naksa would sound better. But as to that figure, I'll leave that to the reviewers. if anyone bought the Naksa, they would have nothing to be ashamed of, not at all.
Hi Ray, pretty much spot on IMHO. One must remember that the Maya and Soraya are fully built and that assembly plus case and transformers etc. account for a fair bit of the cost difference. And I may add, very well built at that.The differences are subtle but definite (again IMO) and taste would come very much into it. I have a wide taste in music and to me the slightly higher detail and refinement levels of the Soraya really appeals to me for orchestral and complex music. But it's impossible not to smile when the NAKSA starts to bop along with Jazz or Vocals or similar. Each to me have subtly different strengths but no real weakness and I think that is something that Hugh can be highly commended for.
I agree with Ray. Buying an amp which can't be heard at home first is cumbersome. I bought the LF100, the NAKSA 70 and Vsonic speakers blind from the other side of the world. I personally did not prefer the sound of the Naksa 70 over the Lifeforce, while it was clear to me that NAKSA is a better amp on some aspects like bass. The question i asked myself is; could i have asked Hugh the right questions which saved me from buying another amp which i won't prefer over my present? hmm i think not. Though, i believe that there are some distinctive topology aspects who could help to make a (more) founded choice. For example the effects of different damping factor and feedback topology. A while ago i presented Hugh an idea to make a little guide about these aspects for the Aspen amp range, which properly can help future customers to choose their 'right' Aspen amp. I don't know if he has thought about that in the meantime? Hugh?
Ray,Makes no difference, but looks a bit more swish......BTW, what Lyn said, he's my man!!Hugh
Really? "I personally did not prefer the sound of the Naksa 70 over the Lifeforce," while that's not a bad thing in itself, why did you prefer the LF over the Naksa? hmmm, I don't know if this is worth persuing, but that would make me wonder if there is still some life left in the LifeForce amps. No pon intended. Ray Bronk
