0 Members and 1 Guest are viewing this topic. Read 19452 times.
John, does this "push/pull" setting mean the subs are 180 degrees out of phase? Thanks. Cheers,Robin
John, My intent with the review was to be as fair as possible, and provide a direct comparison to subs I have/had. I have been recommended umpteen subs in the past, and they always fell short. The best bang for the buck was the 15" dayton titanic III. I felt the burn when I ended up with subs that the maggie crowd recommended the REL, but that sub just didn't have the cajones. The tube-snake boogie subs didn't impact or move air, and the porthole subs all sounded boomy and undefined to me. At that point I said I need to cut my losses and stay with the least overall compromised and that was the dayton. I will not that when certain companies come out with a sub, the press reviews EVERY SINGLE MODEL. How long has it been since there has been any VMPS sub review like the new larger, super solid or VLA? I dunno but I see reviews for seemingly every single other company--and the resultant hype. The VMPS subs are a well kept secret compared to REL, SVS or the others that seem to be mainstream press darlings. At this point, folks can buy what they want...but since I have been there and done that---the VMPS just works better than so many of them it isn't funny. The press should be using VMPS as a reference to measure the other to see how well they (try) to keep up.
I have only had my VMPS for about a week and absolutely just love it!! I'm all ready to purchase a couple more hopefully in the near future. I haven't had countless subs but I do know that I will no longer be looking for anything else. I just can't see how there is another sub out that will sound any better than this.
Construct,Thanks for an excellent write up. I'm so with you on the need, qualities, and requirements of foundational bass. Most ignore the necessity of big room and separation of the amp from the sub.Years ago I had separate bass cabinets capable of114 dB at 17 Hz (6 cu. ft. transmission lines using an 8 inch driver from I. M. Fried). But I lacked a room big enough to allow them to sound even decent. Finally took them to a 20,000 cu. ft. chapel and was blown away using my NAD 3020. They were musical, graceful, and powerful. I was so blown away that I donated them to the church. Probably would be a category 4 sub by your scale.How big is your room and what would you guess is the minimum for this sub?BTW I’m a fan of big B’s style and much of the VMPS stuff. So sad that the Michigan dealer gave up the line.
