0 Members and 1 Guest are viewing this topic. Read 5913 times.
I have a TWO.2 and have no phase issues whatsoever..red is red, black is black..I checked with a THX disk via DVD and it all sounds most excellent!!
AFAIK = ??
hi there,just a quick Q.I understand that some (all?) tripath amps have their fase inverted ... this means you would hook your speakers up correctly connecting the RED speaker post on the amp to the BLACK post on the speaker (fase 180deg inverted)IS THIS TRUE FOR THE VIRTUES?or do I just connect red to red?thx, and cheersAl
Let me give this to you from one blindman's perspective. Hook up your speakers like you normally would. If you have access to a tuner, put it in between stations with white noise. Now, ... if all is not! well, and you need to walk so you are 90 degrees walking from left to right/right to left, if you are out of phase, you will hear a nice hole of sound in between your speakers. If all is well, then you will hear a wall of sound building up as you are walking towards the middle between the speakers. Sorta like a Shevron/arch. Music is a lot harder to detect this, but with a bit of practice you should be able to discern this effect. Hope that helps.
Ray, I think the phenomena you are describing is whether the speakers are in phase or out of phase with each other. As far as absolute phase versus inverted phase (the speakers are still in phase with each other in both scenarios), I don't think the difference can be discerned with wide spectrum constant amplitude white noise. I believe that it would require a waveform that has attack, decay and dynamics. Steve
Steve has explained it well but if it needs simplifying ( ) then basically it doesn't matter much which way you connect the speakers providing that it is a single-amped system (and you hook up each speaker in the same phase).To make matters a bit more complicated, recordings are not always engineered with the same absolute phase so which ever way that you connect your speakers, it is possible that the sound will be 180 degrees out of phase on some albums. Even if your ears can detect that, it isn't really practical to hop up between tracks/albums, and swap your speaker cables over. Some equipment like the Scott Nixon DacKit has a phase inversion switch but I have only played with it a couple of times in five or six years, and then more for my own amusement than making a recording sound 'better'.So there you have it, something else to worry about that many of you didn't even know existed! But as Steve pointed out, it is worthwhile to understand the difference between absolute phase, and relative phase. If you have the relative phase wrong, you will most likely notice a reduction in bass output. Or if you have multi-amped systems, and they are out of phase, it won't sound right either.And don't forget the phase-shift issue with (ALL) class-T amps. If you have a multi-amped system make sure all the amps are class-T(D).Plenty more reading at http://www.google.co.uk/search?hl=en&client=firefox-a&hs=8ES&rls=org.mozilla%3Aen-GB%3Aofficial&q=absolute+and+relative+phase+loudspeakers&btnG=Search&aq=f&aqi=&aql=&oq=&gs_rfai= for those who are interested.
We probably wouldn't be doing this if we didn't love to pick nits (that is half the fun), but don't forget that the vast majority of receivers are class a/b and a good percentage of subwoofers are class D and are often calibrated with software, so I wouldn't worry about phase issues with class d / ab unless something doesn't sound right.
There is a reason that many subwoofers have an inverting phase switch or variable phase control.
All the OP really wanted to know was if the Virtue amps inverted phase or not. He didn't ask how important it was or that he was neccesarily worried about it, and many of us like to provide whatever information we have, but I wouldn't call it nitpicking.
Actually he was just wanting to know whether to hook up his speakers positive to positive or positive to negative and you are telling him that he needs to make sure he has a class d sub with a class d amp.
We flipped the output at the terminus. So no phase issues on this amp.
Which is exactly why it doesn't really matter if you have a class a/b sub with a class d amp or vice versus.
