0 Members and 1 Guest are viewing this topic. Read 60456 times.
CHR70
IMO the Omega 5" hempcone drivers handle high frequencies very well. They can catch the slightest shimmer of cymbals and hold on to it. I can hear the piccolo in a symphony and catch the entire range of the orchestra. (I think! ) However, in order the capture all the lows and their impact a sub is required. I have the Omega Hemp Bipoles that double the displacement so that the little drivers aren't overwhelmed with larger works. The bipoles also help with the baffle step problem and and my homemade felt defraction busters help too. I surprised that the bipole configuration hasn't received more attention by speaker builders. I suppose it's because the form requires a substantial distance from the back wall to work properly. If you have a dedicated audio room the problem is solved. I suppose that, intuitively you'd think that they wouldn't image well but I've found mine to image well enough to place the instruments in an orchestra and small jazz groups it's almost pinpoint. Their main drawback would be the lack of that big speaker feel although it's amazing how those 4 little drivers can fill a room. Also if I push them hard they'll sound stressed at very high volume.
I am building the smaller Dunideer.
I feel a bit lost when looking at some of those plans. What tolerance is typically needed on the positioning of the internal panels?
This is my first build of folded horns so I really have no idea. I would love to get some feedback from Dave, Chris or someone with lots of experience building these types of boxes. I will say that I cannot worry too much over 1/16" or else I would never be done.
Interesting to hear. What (type of) box are you planning to put them in eventually?
Dave's double bass reflex
very interesting wush: wish i could hear them. what do they sound like withthe port stuffed?what about a cab like that sealed (for better driver protection at higher vol.) but with the driver on the big face ( for less baffle step loss)+ 2 subs on the bottom (seem bastani forum for integration info)?
Nice! I need to decide what to build next. Either the Frugal Horn 3 or an Onken with the Alpair10. I sanded up my Dunideers today. Now I just need to finish them.
