0 Members and 2 Guests are viewing this topic. Read 197465 times.
I didn't have much time but I tested the Monoprice unit. The power supply from the Monoprice unit worked on the Port-ta unit. I plugged the Monoprice unit in and the remote from the Port-ta unit worked. I put in an SACD and the DAC locked on the 88.2kHz signal. I put in a 192kHz DVD-A and the DAC also locked on the signal. While I spent less than 3 minutes, I'd have to conclude they are the same unit.Do you have secondary audio set to off?
I guess that I didn't explain myself well..it does work but my dac indicates a 48 k signal even though I have set my oppo to output up to 192 k.I'm using a matrix mini dac.
I have the oppo set to pcm out for sacd and hdmi. It is set for 192k max output. If I play a dvd-a via the coax output, I read 96k on my dac.Any blu-ray ,dvd-a or sacd shows as 48k on the dac when using the monoprice hdmi switcher to coax to dac
oppo bdp-83,,video set for 1080pthanks
Check on all counts,, my switcher is the HDX 401ta,,,perhaps it's an older version??Mine does NOT have 2.0/5.1 audio led after input "4"http://www.monoprice.com/products/product.asp?c_id=101&cp_id=10110&cs_id=1011002&p_id=5557&seq=1&format=1#largeimage
OK, what am I missing here?I have my Oppo 780H connected to the Gefen box, which is in turn connected to the Monoprice box. I've tried both coaxial and TOSLink and get nothing?The Oppo is set up as:- HDMI -> LPCM- LPCM rate -> 192kHz- output -> RAWThe really weird thing? I can now listen to an SACD via the analog audio outputs!? It's not playing the CD layer, since the Oppo registers it as a SACD in the display window? Is the Oppo streaming the SACD signal as LPCM through the analog out?Very puzzling!?
So ... just to clarify ... by purchasing the Atlona "thingy" ... I could do the same tricks with a Sony BDP-S370 as with the Oppo unit(s) discussed in this thread?ThanksDoug
Not exactly. The Sony does not support DVD-Audio. But SACD and Blu-Ray, yes.
