24/192 with older Off-Ramps with new USB Audio standard?
0 Members and 1 Guest are viewing this topic. Read 2987 times.
Recorder
Steve,
The following post recently appeared on the Audio Asylum:
"USB Audio 2 native driver for OSX will support 24/192 with OSX 10.64 when released."
When this becomes available on Mac OS X 10.6.4, will this make 24/192 playback available with older Off-Ramps?  Or would this require an update to the Centrance software in the Off-Ramp?  Mine is an Off-Ramp I2S.
Thanks for all of your great work!
Bill
audioengr
Re: 24/192 with older Off-Ramps with new USB Audio standard?
« Reply #1 on: 6 Jun 2010, 12:51 am »
Steve,
Bill
The Off-Ramp 3 supports up to 24/96 with the CEntrance interface firmware.
I have licensed the M2Tech 192 async interface, so I will be starting the design of a replacement USB module for both the Off-Ramp 3 and Overdrive DAC soon.  This upgrade I expect to cost around $300.  The M2Tech interface still requires a custom driver be loaded, so it does not take advantage of native drivers.
Steve N.
Recorder
« Reply #2 on: 7 Jun 2010, 09:13 pm »
Steve,
I think you did not get my question.  I understand that, with Mac OS X 10.6.4, Apple will implement a new industry standard USB protocol, USB Audio 2.  It is supposed to support up to 192 kHz over USB 2 with no proprietary drivers.  Do you know whether there will be a way to tap into this with the OLDER Off-Ramps, suich as my Off-Ramp I2S?  Or is it too early to tell?  I understand that OS X 10.6.4 is expected to be released shortly and that many developers have copies, to prepare for the transition.
I have not heard about Windows making any announcement as to when they might introduce the new standard in Wiindows.
I already realize that my older Off-Ramp cannot be upgraded to use the M2Tech HiFace drivers.
Bill
audioengr
« Reply #3 on: 7 Jun 2010, 09:41 pm »
Steve,
I think you did not get my question.  I understand that, with Mac OS X 10.6.4, Apple will implement a new industry standard USB protocol, USB Audio 2.  It is supposed to support up to 192 kHz over USB 2 with no proprietary drivers.  Do you know whether there will be a way to tap into this with the OLDER Off-Ramps, such as my Off-Ramp I2S?
Unless CEntrance rewrites the USB interface firmware and I license it again from them, these will be limited to 24/96 with the existing USB interface.
Even if CEntrance did offer this, I dont think it would be cost effect for me to license it from them.  The License is usually $10K.
Steve N.
