0 Members and 1 Guest are viewing this topic. Read 4503 times.
I kinda figured that but I wanted to get some other opinions. Just hard to believe since the 21 has a 30% lower Fs, a 4dB efficiency gain, and almost a 25% stroke advantage...If I do 4 Shivas they will be 2 on each side of the entertainment center, which is quite large, and I should get some acoustic coupling between each two (if that's the correct term), and I know the two sets spaced apart should create constructive and destructive interference at difference frequencies.I must be the only married guy who has an unlimited WAF But even I am tired of raw MDF boxes in the living room for the last 10 years...I mostly want the 21" because of, well, it's BIG! And I'm sure it sounds good. But anything other than a sonotube enclosure would require a forklift to move. And I still haven't seen a sonotube design that appeals to me. Ideal would be mounting 2-4 in the basement firing up through a vent, where weight/looks wouldn't be an issue since they would be permenant. Problem is this house is on a slab.Any other opinions? I'm not fixed on just these two subs, just on the amplifier where a 4 Ohm load is ideal.
Hi Craig,While the 4 Shivas might produce slightly more output, do note that the Mael 21 will be much lower in distortion especially in the 18-30Hz region. Similar case to a 8 inch reproducing 30Hz vs an 18 inch playing 60Hz. Massive difference in tonal accuracy. I'd say stick with the larger driver.
So here is a third idea:Instead of the 4 Shiva-X2s ported, why not 8 Exodus DPL-15s, IB in the attic.This would give me just a little more than the Shivas especially below 15Hz using my current amplifier.Now my concern is with neighbors and heat. Anyone have any experience using an IB in the attic? The motor would be mounted such that it would be in the conditioned space of the house with the front of the cone exposed in the attic. I will read up on another forum that discusses this in great detail tonight, but would still appreciate any feedback.I really don't want to drag a sub up there, hook it up, and listen from outside the house...And this weekend looks like a good time to buy
