Few projects upgraded with PH regulation
0 Members and 1 Guest are viewing this topic. Read 3488 times.
multibit16
« on: 12 Apr 2010, 08:11 pm »
Thought I'd share a few pics and info for a couple of my diy dacs upgraded with Paul Hynes excellent regs, also an external psu for the Duet using the PR3
Monica3
Regs fitted
2 x Z1703v3         input receiver + spdif Hex inverter chip
1 x z1705             input receiver
1 x Z1705v45     dacs  positive supply (Vdd)
1 x S170 0v83   dacs Iref
1 x Z1A-18         Output stage
Buffalo32s
1 off Z1A-8v5 positive medium power shunt reg used as a pre reg for onboard regs
1 off S1701v2 positive mini series reg for DAC core
1 off Z1703v3 positive mini shunt reg for 80MHz Oscillator
1 off Z1703v3 positive mini shunt reg for digital and analogue supplies for the DAC
2 off Z1703v3 positive mini shunt reg (one each for L&R AVCC feeding pins direct)
1 off Z1A-15 positive medium power shunt reg for analogue VA  right
1 off Z1N-15 negative medium power shunt reg for analogue VA right
1 off Z1A-15 positive medium power shunt reg for analogue VA  left
1 off Z1N-15 negative medium power shunt reg for analogue VA left
PR3 set to required voltage makes an excellent regulated pre-reg for the onboard regulators
Squeezebox Duet receiver psu using PR3
« Last Edit: 13 Apr 2010, 12:44 am by multibit16 »
poseidonsvoice
    • 2 channel/7 channel setup
Re: Few projects upgraded with PH regulation
« Reply #1 on: 3 May 2010, 05:46 pm »
Beautiful work! You are an artisan!
Anand. :notworthy:
