Thanks guys.
Trung, my buffer enclosure is partially built, just waiting for the parts. BTW, I picked up a woodburner.
Joe, when I get some time between my son's wrestling meets (off season meets now) I will be glad to have you over. If you don't find a solution to your H frame pretty quickly let me know and we can try to get together to get those cut for you.
Dave,
No, the entire build is MDF (so far, will be using maple for some of the finishing touches). Because of the way I decided to build these I had to get some of the painting completed before veneering. It would have been difficult for me to do afterward although that would be some builders' preference. Yes, the veneer is a Tiger Maple with some birdseye figuring. It will be difficult to see all of the figuring until I start applying the finish.
Best,
Ed
