0 Members and 1 Guest are viewing this topic. Read 14921 times.
So let me try this again. Say we had a computer, into the SS Db Labs dac, then a Dodd tube buffer, and then a 4800A or Cherry Jr., and then 87 db 4 ohm speakers.Would the input and output impedances, gains, flavors, etc. allow the Dodd to actually control the volume???
the balanced pre is quieter with the Cherry
Most of this will be due to the design of the preamp rather than balanced vs unbalanced. My Purity One that was driving the DAC amps was unbalanced with an output impedance of 800 ohms and mated very well with the amps. (The balanced pieces' outputs are 180 ohm). As far as volume setting goes, it depends on what setting the preamp was on. With multiple attenuation settings, I can have gain of 22dB, 16dB or 12dB on the Purity. At full gain, 22dB, I did not have as much travel on the volume knob but still dead quiet. I prefered the 16dB setting on the Purity as well as the 13dB setting on the Basis preamp that I also used with the amp. The Basis can be configured for 23dB, 17dB or 13dB with an output impedance of 1.7K ohms.Average output voltage from sources used was 1.7V-2V.Unfortunately I do not have any one else's preamps around any longer for comparison with the DAC amp. For what it's worth, the speakers I was using with the amp are 93dB with multiple plannar tweeters working from 600Hz on up so if any noise was there, it would have been easily noticed. It proved that these amps can be as quiet as midnight. We are working on bringing this amp back in
Tommy, do you think this combo would work?
Yes, but if I've been looking at the right information, the only volume control is the PC scaling the data before it enters the D/A. I'd be worried about clicks/pops associated with PC audio since you can't lower the volume to be safe when switching sources, etc. There's also the accidental volume WAY HIGH problem and the time it takes to lower it on the PC before you hurt your ears (or speakers). The Cherry puts out a LOT of power and it's better to have a preamp or D/A with a volume control. Maybe someone can comment on the volume "safety" issue with the dB Audio Labs D/A...
The Dodd buffer, with no gain, would be the volume control. It's the no gain parameter that has me concerned.
Throttling it back from 0 db is fine with me. But will it NEED to be throttled back is what I am trying to ascertain. I'd hate to wind up with the opposite effect (need gain, but can't get it w/o a gain stage in the pre).
Bill,When you say "Average output voltage from sources used was 1.7V-2V.", do you mean full scale from the source driving the preamp?
Is anyone here familiar with the "Matrix Mini-I"?http://www.head-fi.org/forum/thread/441960/matrix-mini-i-balanced-dac-hp-amp
i use a balanced version of Placette Audio Passive Preamp: RVC. this works great with the Jerry Jr. i also use a balanced version of the passive preamp made by Luminous Audio Axiom in my second system (HP laptop > USB converter > Stello DA220 > Luminous Audio Axiom > Dynaudio BM5a active speakers). at one time, I put the Axiom in my main system (HP laptop > USB converter > EMM Labs DAC6e > D.A.C. Jerry Jr > SP Tech Timepiece 3.0) replacing the Placette. I wanted to test how good the Axiom is… well, the Axiom falls far behind the Placette. Axiom is more grainy, noisy and lacks details of the Placette. Big difference.
