0 Members and 1 Guest are viewing this topic. Read 11689 times.
are they the "Best in the World"?
There is a 95% copper braid and underneath it there is a solid foil shield. The underside of the foil shield is laminated as well to provide extra physical support.
I chose 4ft as the base length because it is neither too short or too long for most situations. It has no correlation to performance. I can make cables in any length that is required. I am currently using Nakamichi RCA plugs. They're heavy and precisely made. I love the solid feel and how they conform to different sockets to provide a solid ground and a good positive contact. They are not directional or locking.
The shield has to be connected at both ends. A complete circuit would not exist in some cases without it.
Are these wires coaxial with a single center conductor and a two-layer shield? Steve
Although leaving a shield not connected on one end is an option on a 2-wire + shield cable, I wouldn't even entertain the idea of not connecting the shield at one end of a COAX cable! For one, you would loose any possible chance of even coming close to a 75 ohm impedance for digital audio use. And for either digital or analog use, who would want the signal to return through either a chassis ground or separate ground wire? Steve
There is no insulation between the two shields. Copper is braided over the foil. The lamination side of the foil faces the inner dialectic (solid nylon).
Hi Blair,Ok, the point is mute. Thanks. So if I buy a shorter length from you, like the standard 1 meter, what would be the price then? Thanks.Ray
