0 Members and 1 Guest are viewing this topic. Read 30394 times.
Russell - Funny, I am listening to International Guitar Night II on my M60's as I type. The tapping on the second cut (Celtic Medley) is spooky...
Which brings up another interesting feature of the Atma-Sphere amps: They can be run with less than their full complement of output tubes. I used to do that in the summer in New Orleans.
The S-30 has 2 dB of global negative feedback. The M-60 has 1 dB of global negative feedback. The MA-1 and MA-2 have zero global negative feedback. Other OTL amp manufacturers sometimes use higher feedback which results in higher damping factors, making their amps compatible with a wider range of speakers.
You won't hear many contradictions to that! Are the Cyber 845s reliable?
So you're probably hearing it better than I ever have!That's the sort of sound I will use to judge the amount of delay to use on the spot mics (to match the arrival time of the sound at the main mic). When the delay is right everything snaps into focus, especially with percussive sounds and also especially with the relative distances and levels in that recording. The main stereo mic (Royer SF-12) was about 10 feet only from the spots and there was about as much contribution from the spots as from the main in the mix, so it was doubly important to get the delay right. In this case it would have been about 10 msec. One regret for me about that disc is not trying to persuade the principals to allow me to include the lengthy (and entertaining) intro to Aerial Discoveries. The player, Clive Carroll, keeps asking for more and more level from the PA guy, while asking the audience (and me, offstage) if it's too loud. When he finally has enough level, the house is singing like an echo chamber and off he goes into the tune. That's when I fade up, but I should have pressed to include the whole thing.I just finished mixing a recording you would probably like, if you like that one. It was a local young man who plays a phenomenal flamenco guitar. I recorded a concert he did a month ago for his second CD. I did his first 1 1/2 years ago. This time they hired a real Spanish "cantaor" - Antonio de Jerez, based now in Los Angeles, and the energy level stepped up a big notch. The recording is on its way to LA as we speak, to get Antonio's approval for release.Gareth Owen is his name and he is a bit of a sensation in Jerez, being a blond Welsh/Irish kid and playing so authentically.http://www.flamencoguitar.ca/There are sound samples there, but the new one sounds thinner and more authentic and better to all of us, although they were thrilled with the sound of the first one at the time.I guess that's an embarrassingly long OT diversion - sorry, but I would not start a new thread for this info!
I have a pair of Zu speakers at 12 ohm impedance. Any benefit to using the Autoformers to double the 12 ohms to 24 ohms? What would a 24 ohm load do to the S-30 amplifier?
Your speakers have been design to work with a wide verity of rooms and amplification systems. The speakers are also tunable via user adjustable features to better accommodate variance in acoustic space and amplification. Close?
Were you using the Oktava 012s at the guitar? Did you have them modded? Was it running into a ULN-8? Now that's a ribbon sound I like. Rocket_Ronny
At RMAF 2007 I showed my 16-ohm, 94-dB ballpark Dream Makers driven by an S-30. Lynn Olsen, speaker guru dude, played his torture test classical CD at an estimated 110 dB peak at the listening position.
Hey Russell:Were you using the Oktava 012s at the guitar? Did you have them modded? Was it running into a ULN-8?
That same year I walked in with my CD (can't remember which track I played) but also said I want to play it loud. You said "have fun". That moment still sticks in my head as it was insane how loud it would play without any hint of distortion. I never play music that loud but that speaker just wants it. It has such a happy factor it's crazy hard to explain unless you hear it for yourself. Thanks!His Royal HighnessSupreme Emperor and Dictator-For-Lifethe One, the OnlyDuke(yes, this is what Duke wants to be called) I've NEVER forgotton!!!!
