0 Members and 1 Guest are viewing this topic. Read 13978 times.
Hi Gary,I can't answer all your questions, but... 1) At the bottom of the following web page... http://www.digitalamp.com/cherryjr.htm there is a PayPal order button.2) Digital Amplifier Company is located in eastern PA.Hopefully Tommy will be here soon to fill in any blanks.Best, Barry
Barry --- Thanks for the post.Gary --- Please send an email to Support@DigitalAmp.com so I can tell you more.All --- We have a few demos in stock that aren't spoken for, but they have the old chassis version. Write to Support@DigitalAmp.com if you'd like more info.Best Regards,Tommy
Hi Darth-I tracked you here from the VSA circle Are you thinking of using one of Tommy's amps w/ your VR-33s? That'd be sweet!I'm still lusting for a pair of 33's, and I plan on using them with the Cherry JR I now own, and eventually moving up Tommy's line (ooh, that sounds bad) when I can.I actually commited audiophile sacrilidge and sold my VAC tube amp to raise funds for what I'm hoping will be a VR-33 / Digital Amp Co combo in the future.I can tell you that the Cherry amps I've heard do really well with my VR4JRs, so I'm thinking that the match w/ the 33's would be stellar, especially because the imaging w/ the DAC amps is phenomenal (I think due to the sense of total control, top to bottom, I get w/ the amp) and the 33's are supposed to be great imagers, and imaging is very important in my list of sonic priorities.Best of luck w/ whatever you do...-Mike
Gary,There are some things the tubes I had do a bit better - Maybe capturing the resonant body of acoustic string instruments, maybe slightly more ultimate detail of cymbals (but man it's close). But the heat was a turn-off. I knew I'd be getting a Touch and would therefore want to play tunes all day if desired - I just didn't like the idea of consuming 300-400 watts continuous etc. And I lost a tube once and it took an expensive fuse with it and this ~ $100 "inconvenience" kinda stuck with me.But there are many things the Cherry does better - One is imaging, in the sense of precision of image placement, the delineation of instrumental outlines and the overall sense of the size of the acoustic space (larger).A story from one Rave at my place- Robin (Satfrat) was sitting in the left theater seat in my 2-channel room (This room is short front to back, so the outside seats are actually pretty close to the L and R speakers) when we swapped a Cherry in for my tubes. He instantly said "Wow, I can clearly hear the right speaker now" while w/ the tubes he could not.Another is mid-bass definition - I hear a whole world of detail in this region that was glossed over before. And of course the lowest bass cannot be compared - The Cherry is fab at that, especially w/ the mondo Pangea on it.One more thing - Tommy was over one night and we swapped between his digital front-end (Wadia Ipod dock into a small pro-type DAC) vs. my Rotel RCD-1072 CDP, and also between my VAC PA100/100 amp vs. a Cherry (sorry don't recall which one). There was FAR more difference in the sound of the sources than between the sounds of the amps, which suprised me. So, for whatever that was worth...Another factor could be that I'm able to use the balanced outs from my VAC preamp into the true-balanced inputs of the Cherry (vs. RCA to RCA for the tube amp) so maybe there is some synergy there that I wasn't fully getting w/ the RCAs?Of course this is all in my well-damped room w/ my ears etc. Who can say if it'll work to your liking except you.All the best...-Mike
http://www.pangeaaudio.com/products.html
Although I like the Pangea cords (sold by Audio Advisor), I purchased 2 special cords from Mojo Audio that are more flexible and easier to handle. They are not as thick, but I'm pretty sure the difference is 9 gauge wire versus 10 gauge wire as far as the thickness. The Mojo cords also have non-plated (pure copper) contacts. There's a ferrite sleeve on the amp side and nice "Cherry red" connector shells. However --- these cords don't appear on the web site yet. Maybe Ben from Mojo can comment...
Hey Mike, I'm glad to hear from you. Quick question, do you miss that "Tube Magic"? I had owned the Spectron Musician III in the past and ended up going back to tubes? I did like the 500wpc!! But the amp didn't "involve" me in the music like my tube monos do. But after reading some info from Bill @ Response Audio (a big time tube guy himself) and I respect his opinion, that made me look at the Cherry amps. Plus my monos throw off a lot of heat and I have to set the AC pretty low to keep my listening position comfy!! The 30 day trial period will help a bunch. BTW, my 33's are really singing now!! I also bought a pair of Audio Prism's Ground Control Reference. All I can say is WOW!! They are an amazing tweak!! I also have a pair of the regular GC's on my amps. Take Care my friend,Gary
Well, I’m not missing my tube amp. No heat, less electricity, no biasing, no balancing, and I’m sure I will never miss inopportune blown fuses, tube failures, or the hassle from buying mismatched matched sets, etc.As for sound, I think it’s a matter of taste and priorities. I think the difference between my tube amps (Music Reference RM9 MKII, Moscode 150 (a hybrid), and Wolcott The Presence) and DAC’s Cherry Plus is like the difference between a sharp camera lens and the same lens with a diffusing filter on it. A diffusing filter may be nice to hide wrinkles on a middle aged face, but not so nice when your subject deserves crystal clarity.In the switch from tubes to a Cherry Plus does my system capture the resonant body of acoustic string instruments? For sure. More than is real? No. Less than is real? Probably not. What about the ultimate detail of cymbals or triangles? More than is real? No. Less than is real? Absolutely not.Last weekend I went to the opera. Because of the solo, unamplified singing, it is a very good way to hear the real thing. While I was there, I kept thinking, your system has never sounded as close to real as it does now. The next day, I played a CD of the same opera and confirmed that impression.As I’ve posted before, in my opinion, if your priorities are to clean, pure, transparent, effortless sound, you should check out a Cherry Plus, even if you have a predisposition to tube amps.Are the DAC amps the best in the world? I wouldn’t have a clue and would never say such, as I’ve not auditioned many amps, and especially not Class A designs, which may perform as well, but which I dismissed for cost, power consumption and heat reasons. What I can say is that in my system, the Cherry Plus is a clear improvement from my Music Reference RM9 MKII tube amp.
Nice reply, thanks. Though I never have had the issues you speak of with my tube amps other than heat in the summertime. And if my electric bill is $50 or $150 I really don't care (I enjoy music that much). I was only looking for an amp to use in the summertime due to the heat or for my second system?? But since I can't get Tommy to respond to my inquiries, I think my search will go into a different direction. But I do appreciate your's and Mike's insight. Thanks again guys. Gary
