0 Members and 1 Guest are viewing this topic. Read 8853 times.
Pardales, here's the answer to your 1st question. It's a separate player but uses the iTunes database.more info
Does anyone know Pure Vinyl's history of version upgrade charges? I wonder what the costs will be for the upgrade to the non-beta version and subsequent updates and upgrades.
As much as I like it and like Rob's customer support, it continues, like its PureVinyl big brother, to have issues with sample rate changes with my Weiss DAC2. It will semi-randomly hang on a change (usually the second or third sample rate change), thus rendering it unplayable until I reboot the app. Amarra, OTOH, handles sample rate changes flawlessly. Not comparing sonics, just functionality.
ted_b:How do the sonics compare, if you have an opinion?
It just seems like a sin that any mac/pc music player would modify the digital bits before shipping them out to toslink port or even a usb port. What exactly is PM doing here? I do know that iTunes or any other media players won't adjust the built-in toslink settings from 44/16 to 96/24 when you change between different fidelity sources nor would I expect it to adjust the dozen or so USB dacs between 44/16 and 48/24. It's just the nature of the OSes and the Applications that run on it, it's far from perfect. I would expect the goal here is to reliably provide the source unmodified to a dac whether it's via a file or s/pdif. Any imaging or sound improvements would then be on the analog side of the dac.
The makers of Pure Vinyl have released the playback-only portion of Pure Vinyl with all the original music server functionality (minus the upsampling which is supposed to be added soon). Currently on sale for $79 till the middle of the month, after which it will go to $99. A good deal if you ask me, as the playback portion of Pure Vinyl is quite good.Pure Music Player
