0 Members and 1 Guest are viewing this topic. Read 340878 times.
Yes the DCB1 is a cut above the B1 even with TX2575 although I also use TX2575 in my DCB1. I purchased boards only and used exotic parts. Mine is the hotrodded version running at about 600mA.
Can the B1 be built inside an all wood case or do you all think there will be a hum issue?Thanks
I think it is the board - if you look at the left/right inputs for 1 the left goes to the bottom pin on S100 and the right goes to the top pin of S200!Alan
I know that this is an old thread but I am going to build the B1 for my son Parasound A21 amp.I am curious as to what caps people are using. I want a slightly warm, detailed, tubey sound with good air and transparency. I am using Vishay TX2575 1K resistors in the input section and Carbon Riken 1K resistors in the output section.I would appreciate any comments on caps as well as resistor selection for the remaining 10K, 15K and 221K resistors. I was considering trying some PIO caps but I am open to suggestions.Has any one used a remote volume control?Thanks!
Nice build Navi. I just ordered most of the parts. I went with Mundorf MCap Supreme's for the 1uF's and Clarity ESA's for the 10uF's. I was going to go with the Obbligato's instead of the ESA's but I am leery about their bass being a little too thin. I can always swap in the Obbligato's.For resistors I went with the Tx 2575 for the input and Riken Carbon's for the output. Other resistors are Audio Note Tantalums, Takman Rey's and Vishay-Dale's.I am thinking about using one of these case's - the A28-A or the A28-Chttp://diyclub.biz/catalog/index.php?cPath=1_284_298And this Remote AlP's volume pot-http://diyclub.biz/catalog/product_info.php?products_id=601I would prefer a 20K or 50K pot but I can't find a decent kit for a similar price.
