0 Members and 1 Guest are viewing this topic. Read 8163 times.
Pretty system and room, I'm sure it sounds great. You might want to experiment w/ moving the subs around, so that you have a non symmetrical arrangement. You might find it smooths out room modes even better.Curious about the guitars. The yellow one, could be any number of things, but the red one has me baffled. What amp do you use for those.
Very interesting -- I don't have subs but my one real experience listening to them in a dealers set-up convinced me that the addition of subs is less about adding strength to the bass frequencies than it is about freeing up the main speakers.......
Gavin-At what frequency are you crossing the subs with your 5's? As you know, I've had a bit of experience with this myself and am no longer using my sub in 2-channel. Depending upon your answer here, I may start playing with the sub a bit. You can't go wrong with Velos - they were talking about having the new replacements for the DD's ready towards the end of last year, but I guess the economy, etc. slowed them down a bit. Did you talk to Carl in AZ? Very nice guy and very helpful.
Hi Gavin.I would like to know how you measure the freq response. If you measure with SPL and using pink noise and octave bands then you really don't see much, by meaning that you don't see between the octave bands freq. And what about the reverberation time at those freq. By adding subs dosen't remove the modal resonances, you just reinforce the modal problems in your room. Thanks
Wow...18" x 18" x 18" and 136lbs....this is some serious sub!!! I'm intrigued by what this would do with a pair of VR5s....not just any pair, though...mine specifically! Someone, please report on how it all sounds.....
A pair of em could bring you a couple of steps closer to this..........
