0 Members and 1 Guest are viewing this topic. Read 3090 times.
What is the sensitivity on these speakers?
From the website:Final system sensitivity is 84-85dB/2.83v.
That sensitivity is pretty normal, shouldn't be any problem driving the speakers.If the sensitivity was really low then the Virtues wouldn't have enough power to drive the speakers and you really need a high power amp.I had the Virtue Two hooked up to these speakers and the match was outstanding.http://www.gr-research.com/index.asp?PageAction=VIEWPROD&ProdID=148
