0 Members and 1 Guest are viewing this topic. Read 1004512 times.
Thanks for the help. I will go with the AS-4435. Hopefully the upgrade will yield a little more oomph!The amp can definitely use a little more gain as well.Has anyone changed any of the Resistors or Caps?
Hm, I dunno 5.5A cap for your Maggies sounds kind of low from what I've read about them. I seem to recall them needing more power earlier in the thread. I have a feeling you need either a MUCH bigger transformer or a higher power CDA amp, or both. Probably need to beef up the caps too if you have the stock ones.
Do you think jumping up to a 500VA or 600VA transformer would help?
If I wanted to replace the caps in my current power supply, what values do you recommend? Are there any caps with a warmer sound for this application? I have no problem soldering. Or I just may buy the bare power supply board for $40.
Would the 6800uf 63v caps be ok with this Antek transformer for the CDA or do I need lower voltage caps?http://www.antekinc.com/as-4435-400va-35v-transformer/https://www.banzaimusic.com/Panasonic-TSHA-6800uF-63V.html
It might also be related to an appliance with a motor that cycles on and off, like a refrigerator or an air conditioner.Steve
To me an amp should not be treated like that. It should just work with a simple power chord. To buy other treatment products, I also not sure whether it works, could end in give more problems than solving it.
I'm from Malaysia, currently having a pair of Wharfedale Denton 80th Anniversary, amplified via Marantz PM6005, distort when volume pass 12 o'clock, also feel that the speakers need more juice, thus I have ordered SDS-400C since got offer price, I'm using JDS Labs ODAC, no preamp yet, any to recommend? What happen if I drive directly using ODAC?
