0 Members and 1 Guest are viewing this topic. Read 1004569 times.
While not specifically forbidden, it's sort of bad form to link your for sale ad in the middle of someone else's thread. That's what the for sale section is for. However it's not an egregious offence and could actually help someone that might be looking for a kit, so I wouldn't ask that you remove it. In fact if it was a completed kit I might have been interested, lol. No worries.
I'm from Malaysia, currently having a pair of Wharfedale Denton 80th Anniversary, amplified via Marantz PM6005, distort when volume pass 12 o'clock, also feel that the speakers need more juice, thus I have ordered SDS-400C since got offer price, I'm using JDS Labs ODAC, no preamp yet, any to recommend? What happen if I drive directly using ODAC?
Hi guys, I had bought Class D Audio SDS 400C, overall I'm very impressed with it, but I have some "fan" noise coming from the amp, from time to time, though not often, and it just comes out for like few minutes? Any thoughts? Can guide me how to fix this? I've try to contact Class D Audio, but there is no response, anybody know what's going on?
Are you saying there is a "fan" noise coming from amp chassis? Or is it a fan-like noise coming from you speakers? Curious, since I don' t believe the amp has a fan. If coming from the chassis it could be some transformer noise. I get this from the toroid transformers my subwoofer amps whenever my wife has her hair iron plugged in... drove me nuts trying to troubleshoot since the iron turns on/off to maintain temp. Doesn't really sound like a fan, but makes a buzzing sound that I suppose might sound fan-like in your case.
Yes, exactly How do you solve that?
I have an SDS-440C and recently tried shorting plugs on the unused RCA inputs, a tweak that's supposed to keep out unwanted EMF/RF. It seemed the worst that could happen would be no detectable sonic benefit, but instead it seemed to degrade the sound and require increased output from the preamp to maintain volume. Has anyone else experienced this, and does the toggle switch for balanced/unbalanced make this totally unnecessary in the first place?Thanks.
addendum: I see one of their beefier ones use TI.Do they use others' as well?
3 FC panasonic caps of 1800MuF each, in parallel, are connected between de (+) and the earth input screw pins, 3 other ones between the earth and the (-) pins.The mod is very simple to complete,one hour work is really a maximum.
I've sent several emails, still no reply from Class D Audio. I dun want to say this, but it's horrible service. The toroidal transformer hum problem still there. I've lost faith in Class D Audio, totally helpless , I'll have to look else where, good sound but bad service is just what I can said
Question: have you tried taking the amp to a different location (friend's house, work, etc.) and plugging it in to see if the hum is present? That way you know if the issue is with the transformer or something in your home power/wiring.
