0 Members and 1 Guest are viewing this topic. Read 995163 times.
Well, the IR2092 amp has gotten so popular that sure enough there is now a, er, Sure board. Just the amp module, not a kit...[/img]
More generally, with these things does one need anything besides a PS with power cord, box, and SpeakOn jacks for speaker output (because they're both markedly superior to binding posts in terms of safety and usability, and cheaper)?
Hi,i had build a SDS-254 Kit and it sounds fantastic.I would like to express my sincerest thanks to Tom and community to provide and support such great device.Attached some pcitures of my DIY Stuff and Amp.RegardsMarcus
Well, im joining the ranks of the Class D Audio users: I am placing and order for the SDS-470 with the new case this week! Will be using the amp to drive the Gallo 3.1s. As of now, I dont have a premap and Toms suggestion was just to use the amp with my Squeezebox volumes control, he said it sounds great so im gonna place my trust in him! Wish me luck.
That will work, just remember to turn the volume down when you stop listening. If you power up your system and the SB is at moderate to high output, you could damage your speakers. It's sort of non-intuitive to turn down the volume on a device like an SB every time you stop using it, unlike the volume control on an amp.
I was shocked that this works. For some reason I thought the volume control on the SB Touch degraded sound quality below 80%? Maybe thats just a myth?
