0 Members and 2 Guests are viewing this topic. Read 346478 times.
Brian Bell chipamp.com LM3886 gainclone or Class D Audio CDA-224...?Some of you have experience with both amps, so I'd really like your input.
The SDS-450 is made to run very tough loads... even below 2 ohms. It puts out 150W RMS per channel into 8 ohms, 300W RMS per channel into 4 ohms, and 600W RMS per channel into 2 ohms. It's a very powerful amp. It looks just like, and is the same size as other SDS amps. It has the same sonic qualities as our other amps meaning it is one of the finest sounding amplifiers available today. You can read some customer reviews here, and the first is in regards to this amp... http://classdaudio.com/index.php/testimonial We have one other amp called the SDS-470 which does put out 250W RMS into 8 ohms and 500W RMS per channel into 4 ohms. It's also made to run tough loads. The cost is $590.00 plus shipping cost. Shipping here in the USA is about $25.00 to $35.00. we use all top of the line components and my tech is really a perfectionist and does a beautiful job assembling them.
Tom finally got back to me with this reply:This sounds like an incredible bargain to me...definitely cheap and cheerful. I think I may give it a try.
WGscott-No problem. You post enough at the various forums ...
I can always order a custom faceplate or build a wood enclosure and improve the looks for a modest sum.
The SMPS from Connex takes quite a while to get shipped to the US, and costs more than the power supply that Tom offers with the kits. I've tried both, and I'll be darned if I can hear any difference between the two different power supplies with the SDS 254 amp module.
Hi All,Just for understand, why my first post is stopped? maybe it is a publicity...I think it is a information for diy.Regards
New model, SDS-470. 250W X 2 @8 ohms, double output @ 4 Ohms. http://classdaudio.com/sds-470-and-power-supply.html
Where do you find the specs? When I go to the page you linked it only shows the details "SDS-470 amplifier with large power supply ". The complete SDS-470 amplifier page also has no details other than "Custom made SDS-470 in Silver Desktop Case wired for 50 cycles, 220V". The SDS-480 kit page reveals that it is an "SDS kit including two SDS-224 Amplifiers, transformer, and large power supply". I also checked the Manuals page, but there are only the original manuals for the original amps before there were CDA or SDS model designations. It's good that the amplifiers work well and the majority of builders are satisified, but the information available on the website is still to this day as confusing and sketchy as ever and hasn't yet given me the confidence to take the plunge. Maybe there will be details available soon for the new assembled amplifier offerings. Steve
