0 Members and 2 Guests are viewing this topic. Read 1004576 times.
Use high quality 1% resistors: 560 Ohm = 31 dB 1K = 30 dB2.2K = 27 dB5.2K = 23 dB6.2K = 18 dB7.5K = 16 dB
Well, I just ordered 4 of the Vichy naked 2.2 K resistors, and they are on their way, so I am hoping I can figure out how to attach them. Is it possible to re-use the Molex connectors? I have no idea how to get them to let go of the wires.
Fills the room better at low volume
Finally took the time to get the SDS254 I got from Wush hooked up. Thanks Ainsley!The SDS replaced a Yamaha M80. Speakers are Zwaves from the big thread at AK. Started with a CD in my cheap 5 disc player. When the music first started I wasn't sure I liked what I was hearing. So much more detail that my first reaction was that it would seem harsher, more fatiguing. The Selenium drivers are not smooth to my ringing old ears. The sound I am going for has to be smooth so as not set my ears off. I detest harsh or bright.Within less than 2 minutes I knew my initial impression was wrong, very wrong. While the sound is definitely more detailed it is also much smoother and much more open. Fills the room better at low volume while still being able to hear all the music. Snare drum hits have more attack and detail yet somehow are smoother?? and easier on my picky ears.Switched to some Marshall Tucker on the TT. HOLY CRAP!! The difference is amazing. Guitar sounds like my son is in the room with his Taylor. Bottom line is I shoulda hooked this thing up much sooner. Thanks to everyone that has contributed so much to this thread as it is what got me to this amp. Gotta go. My typing finger is getting tired.
What power supply configuration did you end up using? I was thinking about getting the SDS254, but haven't decided which supply config to get with it.Ray Bronk
I using a Dodd tube buffer with DR6H30 tube with my class d amp can anyone suggest what value resistors to use with this set up. Mike
