Does Playing Pandora on an Iphone eat up minutes?
0 Members and 1 Guest are viewing this topic. Read 3428 times.
lokie
« on: 13 Jan 2010, 07:21 pm »
I have found some great music on Pandora. It's my number one new music finder tool.
BobM
Re: Does Playing Pandora on an Iphone eat up minutes?
« Reply #1 on: 13 Jan 2010, 07:24 pm »
You can also try www.lala.com
Good stuff out there these days to let you give a listen before buying. I especially like it at work. I can put on a set of songs from one of these sites and give a listen on my headphones while I work. That is, as long as the corporate firewall allows it through.
Crimson
« Reply #2 on: 13 Jan 2010, 07:27 pm »
No minutes are used. It's part of your data plan.
carusoracer
« Reply #3 on: 13 Jan 2010, 08:42 pm »
I'm not sure about the minutes but Pandora station is one of my top favorites 8)
jqp
« Reply #4 on: 13 Jan 2010, 11:33 pm »
Actually it eats up minutes but the data plan is $30 for unlimited use :) and it is data
lokie
« Reply #5 on: 16 Jan 2010, 03:45 pm »
My latest station I've been digging is "Martin Taylor and David Grisman".  If you like Jazz with a funky, folkish bent give it a try.
