0 Members and 1 Guest are viewing this topic. Read 341713 times.
Hmm.. does anyone know how the tranquility compares with the bel canto dac 2.5?Also, how would the tranquility compare with cdps such as the marantz / rega/ naimThanks for feedback
Hmm.. does anyone know how the tranquility compares with the bel canto dac 2.5? Also, how would the tranquility compare with cdps such as the marantz / rega/ naim
The Audio GD clobbered the Belcanto
Which "Audio GD"? There is like a dozen different Audio GD DAC's by now..
I took my Tranquility SE down to a local Hi Fi store yesterday. When the guy heard it he started scratching his head. I asked what he thought. He said - man is this thing accurate and neutral but it has not a trace of coldness or analyticality - its just so liquid and smooth. I asked how it compared to the vinyl stuff he sells. He said while he sells it he actually doesn't like vinyl - too many clicks pops etc. He has a highly colored DAC himself he likes so off the top of his head he thought the Tranquility was not to his taste. I have heard this mentioned before and think I know the cause - to really show this DAC off you need some well recorded material. OK I pop on some material I know is well recorded like Tom Jones Praise and Blame. Wow that sounds really good. He listens some more - the more he listens the more he says - this DAC is growing on me. He listens further and says how much is this DAC and I tell him. You can get that sound for this? He thought it was a $10K DAC. The final verdict was he can see this DAC really growing on him and can't believe it costs so little for what you get.ThanksBill
Man, you need to start working for db Labs and get paid for what you do ...
The Ref 5ThanksBill
The 2010 Mac Mini is a game changer for the Tranquility SE. In this configuration, the Tranquility SE exceeds the QB-9.
Do you mean Tran SE+Mac mini is better than QB-9+Mac mini and/or QB-9+MacBook Pro?
This makes sense to me, as you would expect asynchronous USB to be generally robust and resilient against varying quality of transport, so long as those transports are at least bit perfect.
