ICE based amps with TVC?
0 Members and 1 Guest are viewing this topic. Read 3411 times.
milpai
    • My Dedicated Audio Room
« on: 3 Dec 2009, 08:30 pm »
Hi,
I was wondering if anyone has used any ICE based amps with the TVC. I am specifically looking at Wyred 4 Sound's SX-1000 mono-blocks at the moment to go with my Reference C-Core. But the sensitivity is a bit low at 2.95V (for 570W at 8Ohms). My CDP outputs 2.2Volts. Not that I require 570W, but it is a "good to have feature". I checked with Nicholas and others and the suggestion I get is to keep the sensitivity <= 1.5V.
milpai
Re: ICE based amps with TVC?
« Reply #1 on: 20 Dec 2009, 06:07 am »
Wow....no one on this forum has used TVC with ICE based amps?
rollo
  • Rollo Audio Consulting -
« Reply #2 on: 23 Dec 2009, 07:44 pm »
Nic is correct. Are you sure the input sensitivity is 2.95 ? seems high. That said it means you will have to turn up the volume control quite a bit and still may not have enough volume or dynamics. Check out D-Sonic. IMO just as good as the Wyred, same people I believe.
charles
milpai
« Reply #3 on: 25 Dec 2009, 03:07 am »
Thanks Charles. I have lately started to look into Channel Island D-200/500, as they are are designed to be used with a passive preamp. And they seem to have a gain of 38 db for passive preamps.
