0 Members and 1 Guest are viewing this topic. Read 4324 times.
I'm thinking that the 9 would be best on the lower base with the tubes on the mid/tweeter. Anybody using similar setup or any ideas as to which should be used?
What does the input sensativity matter?
Quote from: Coytee on 25 Oct 2009, 03:57 pmWhat does the input sensativity matter? If you're actively bi-amping with an active crossover that has adjustable input attenuation, then like you say, it doesn't matter. If you're passively bi-amping, and the amplifiers themselves have level controls that can get them to the same level, you'll be fine. If the amplifiers have no level controls, you would want them to have the same input sensitivity and gain.
I would have thought to get the most from biamping, someone would have an active crossover in the path to divide the signal prior to the amps.Never thought of the way you're mentioning it, I see why in that example someone WOULD indeed care about the input sensativities.
And you would be absolutely right. Active bi-amping requires an active crossover, and either the speakers are wired for it (no internal crossover), or you have removed or disconnected the internal crossover and wired directly to the binding posts. It adds some complexity that many people do not want to undertake. But passive bi-amping is quite popular because it is easy, though it can often result in marginal improvement because the internal crossovers in use are still soaking up power and adding phase distortion, etc. Yet some people claim the improvement is more than marginal in their systems. But one thing it can still accomplish is the ability to give a solid state grip and control to the woofers, and the liquidity of tubes to the mids and highs, if you're using both solid state and tube amps and prefer those attributes. Steve
