0 Members and 1 Guest are viewing this topic. Read 6856 times.
...so I guess resolution is more important than bit depth.
I think, when you listen to hirez music, you listen to increased resolution AND bit depth. I have no clue what one would do without the other. To spend a lot of time debating 16 vs 24 seems to be debating one hand clapping. I guess we could listen to 16 bit downsamples (like what comes out of Oppo's coax while playing DVD-A) and compare. i like what I've heard, so I guess resolution is more important than bit depth. But how many 16/96 recordings are out there??
All I know is that my 24/96 and 24/192 recordings are quite wonderful.
I would submit that both sample rate and word length (what some call "bit depth") are both measures of resolution.
...Does this make sense?Danny
That's been my experience as well. Though some people have suggested the reason most hirez content sounds better is due to better mastering rather than greater resolution. I think it's probably a little bit of both.--Jerome
Quote from: bdiament on 3 Sep 2009, 01:09 amI would submit that both sample rate and word length (what some call "bit depth") are both measures of resolution. Totally agree!I always record to 24 bits and 44khz when I make my own amateur recordings because I can hear a significant improvement over 16/44. I doubt that I actually use all 24 bits but the extra headroom seems to help on my hard disk recorder.I also prefer the crude truncation of bits down to 16 when making a redbook CDR instead of trying to "dither" it down to 16 bits. But then again, I'm just an amateur.
