0 Members and 1 Guest are viewing this topic. Read 25052 times.
I'm thinking about using one of the bigger models...like the 2700...and replacing the plug with a 15 amp plug. The biggest model with a 15 amp plug will only handle 1050 watts, which at 120 volts is only 8.75 amps.The 2700 model can take 1890 watts which at 120 volts is 15.75 amps and only slightly higher than my line is rated for. The limiting factor will still be the breaker, which won't let you pull more power than the 15 amps. I want to be as close to this 15 amps as possible. Anything wrong with this thinking?Thanks,Jim
Did you test the batteries yet?
Now maybe I can request one that's been cryo'd.
