0 Members and 1 Guest are viewing this topic. Read 33970 times.
So, how do I know what frequencies will couple and what frequencies will cancel each other out?
so, do those stacked planars actually increase high frequency sensitivity?
Instead of various ribbons tweeters I would prefer the Carver Amazing 60 inches ribbons and a half dozen of subs like the Gilmore Audio Model1, now with a SPL of 91,5dB. Anyone know if this Carver 60'' is sell as raw driver??
I'm thinking, high frequency cancellation may be an advantage for a short array of full range drivers. most of paper full range drivers have rising frequency response.say we build sealed or ported enclosure and add just enought drivers to balance low frequency gain and high frequencies cancellation.of course top end response will be rough, but I bet it will sound better that single full range used without any sort of filter.
Thankyou Danny/BPT for sharing your impressions about the BG RD75, if it have a nice Dipole Soundstage it have some sex appeal to me, cause it is bigger than the 60'' Carver Ribbon, bigger is always better, as all women knows (sorry).Iam illeterate in xovers, what is this notch filter after all??Kinds, Gustavo
...dramatically rolls off above 10KHz.
Incidentally comb filter effects are not confined to line arrays. They are also produced by two or more sources of the same frequency and even one drive unit and the reflections from room boundaries can generate them. Because of this we are all used to comb filter effects in our sound systems, and, as I do not see everyone rushing to dump their loudspeakers in the bin, I would suggest that comb filtering is relatively benign on the grand scale of annoying distortions or perhaps the majority of us have learned to filter the effect out of our minds.
