0 Members and 1 Guest are viewing this topic. Read 993620 times.
PROBLEMS WITH PANELSThe biggest problems with the sound of these panels is getting used to so much detail. If you have a natural recording in a church, lets say, the sound can be amazing! Astounding!! But if you put on one of your favourite studio recordings, you can end up listening to the studio engineer doing his job, for better or for worse. Sound effects such as echo, phasing, distortions to enhance a voice, are designed to sound acceptable on normal speakers. But on these panels one hears the machine making the sounds, sounds put in and removed - fascinating but Not Good. Consequently, may have to keep old speakers to listen to these recordings.
Sedge,I will say subjectively that the panel does sound brighter on the backside, definitely the one with the sheetmetal insert. Though the increase in HF may be due to boundary reflections.
"Ultrasonics are out of reach, but the midband is utterly transparent and clear."
Fullrange,When I came across that material chart the other day, I figured it must have been a misprint and is instead correctly Kg/m2. Also I believe I read they suggest glue for mounting, the picture is a little deceiving because they have an integrated suspension/surround surrounding the exciter foot, howver the black plastic surround looks like it pops on/off but you would have to find out if they glue the exciter foot to it upon assembly. As shown you glue/tape the black surround shown I imagine.
My apologies..............as I got you guys very excired about the Elac exciter.Unfortunately, the product (Imago loudspeaker) was discontinued and is no longer available.Yet...............the manufacture date on the back of the exciter indicates it was made in 2008 ????
