0 Members and 1 Guest are viewing this topic. Read 54217 times.
The Tommy isn't sourced from SACD, but from a 2 channel mix. HDTRACKS converts SACD to 88.2, not 96.BTW, I emailed Michael Fremer,who's quoted as endorsing the files on the HDTracks website, and he confirmed that he very much likes the tracks. Says they are the best version he's heard other than his original Track Records LP. If you're in the US you probably don't have that version but a crummy sounding Decca America or MCA version
Which 2 channel mix? Is HDtrack going to use mixes with the original, sweetened, drum tracks, or the clean ones from the DVD-A & SACD releases? I'll take the mixes with the clean drum tracks over any version released previous.
I don't remember where I read it, but apparently it is a mix based on the work done at the same time as the SACD and DVD-A.
Was there a promo code off HD tracks for "Tommy" ?
yes "save4minutesattheend" gets you a.........just kidding. Seems HDTracks doesn't quite get it yet. They are sending out response letters that state the extra songs on Tommy were a special pressing, not available on HDtracks, and that most sites only sell the 24 song album!! The requesters, however, don't give a crap....they sent these letters to tell HDTracks NOT about an extra song, but about the 24th song being cut off by 4 minutes!!! Yikes.
