0 Members and 1 Guest are viewing this topic. Read 33800 times.
rrbert,Thanks for the advice. I installed the backdated Java and then downloaded DVD-Audiofile. When I tried to open DVD-Audiofile I got this message:Sorry for the convoluted screen shot, but I did this on a different machine.
I can try to make a version that works on the current os on Monday
May I ask what conversion program you use?When I use xACT, going from wav to flac it make the files 16bit. Is there a setting somewhere to keep them 24 bit?Going from flac to wav, the files stay at 24 bit.
xACT doesn't convert 24 bit wav to 16 bit flac. It just tells flac to compress and that's it. Files will be the same bit depth as the originals
Glad it worked. You can burn files with different resolutions to DVD-A, but you have to use separate "groups". All the files in any one "group" need to be the same resolution.If I do some editing on WAV or AIFF files, I always convert them to FLAC before using DVD-Audiofile for Mac. Interestingly, the Windows version (which you can't even find anywhere anymore) works fine with WAV files.
