0 Members and 1 Guest are viewing this topic. Read 10033 times.
Quote from: Welborne on 19 Jul 2009, 06:09 pmdear 1000a, I have both 90watt and 130watt ps. After you have compared them, you won't go back to 90watt one. You may not be able to hear a very big difference if your speakers are very sensitive in the range of 93db-100db, but when you are using them to drive less sensitive loudspeakers, the difference is not so funny. Are you running mono amps? Thanks, 1000a
Do you find the red to sound a little warm and the white to be cooler?
Quote from: Cheerwino on 22 Aug 2009, 03:21 pm Do you find the red to sound a little warm and the white to be cooler? Hm... using one per channel, the sound is more metalic... more harsh... with less bass... very hard to listen to, all the sweetness is gone... The combination simply sounds... bad It is strange, I expected quite the opposite! Maybe the new one is still not broken in and is masking the old one...
No reason it should sound worse. I would check polarity for sure. Do you have a test tone or track for that?
No, clipping is a function of the input signal and nothing else.I'm surprised this doesn't work for you. It works great for me and many other Virtue owners. Wonder what's going on......
The lack of bass could be seen as better controlled lows?
Quote from: dcolak on 25 Aug 2009, 12:01 amThe lack of bass could be seen as better controlled lows?Very possible. A lot of effiecient bass speakers actually need a low damping factor amp to get any bass at all. Think tube amps. With something like the klipsch, you might test some series resistance to lower the damping factor and restore tonal balance. Anything from 1/2 an ohm up to ~4 ohms. I've had to do it with some speakers.
Quote from: panomaniac on 25 Aug 2009, 12:44 pmQuote from: dcolak on 25 Aug 2009, 12:01 amThe lack of bass could be seen as better controlled lows?Very possible. A lot of effiecient bass speakers actually need a low damping factor amp to get any bass at all. Think tube amps. With something like the klipsch, you might test some series resistance to lower the damping factor and restore tonal balance. Anything from 1/2 an ohm up to ~4 ohms. I've had to do it with some speakers.This must be why my Horn Shoppe Horns don't make much bass with the Virtue One. I use a sub to fill in, so it's not a problem and it sounds really sweet in the mids and highs. But, it is much 'bassier' with the 30v/130w PS than the 90w PS.How would you go about adding resistance, Michael? I'm not a DIY/techie type, so I'd have to get someone else to do it. But, I'm curious to know what is involved, if you could explain--and what the trade offs might be.Thanks,Guy
You are correct! Series resistance is what you want. Use a 10 watt resistor made for crossovers and you will have no problems.With a series resistor you can change to tonal balance of some speakers. The lower the Qts of the bass driver and the higher the damping factor of the amp, the more difference the resistor will make. Both the low Qts and the high damping factor in the amp are indications of "damping". You can lower that damping with the resistor. Very thin cables can have the same effect. So the woofer is not do tightly controlled. Sometimes needed to get any bass at all.
