0 Members and 1 Guest are viewing this topic. Read 80440 times.
Mirage (last generation)Morrison AudioDuevelLinkwitz LabsMartin Logan (most recent electrostats)Ohm WalschDecware omni's Gee, can you tell some of my biases?
You look like an omni and planar/dipole man! I notice you don't mention Magnepan. Do you dislike them?
No, no dislike on my part. Mine was definitely an incomplete list. Others could include:MagnepanMBLMur Audio (world's first omni electrostat!)B&O Beolab 5etc.My point being, I prefer the open, omni and "figure 8" sound for classical rather than what is typically produced from standard box speakers.
To listen orchestral music: open baffles with two big subwoofers 15" or 18" (closed) is a winner combination in a BIG room.
Are even the MMG Maggies good or do you have to live up to the higher end models? I'm tempted by MMG if so, can't really afford higher at the moment
after more 40 years of experience as both a hifi listener and a musician, i can say that sound levels in a concert hall might seem very high, but indeed they are not.it's huge sound, but not so loud in terms of dB.only when you're part of the orchestra and are sitting behind some loud brass or timpany etc. it can be to loud (that's why many musicians use hearing protection).next time you visit a concert take your iphone dB-app and test for yourself. even when sitting in the 1-10 rows and in the middle of the concert hall - dB maximum at a hector berlioz concert of beethoven's no. 9 symphony will never show more than about 85 dB on your dB-app. it will not be 100% accurate - but it's a good mark for listening levels at home.good listening starts with normal sound levels - if you hifi system only sounds nice at extremely high levels, something might be wrong with you setup. (or your ears).
Here in Atlanta I've pulled out my iphone and Sound Meter X app and found peaks approaching 95 and 100 db. Its an old hall built in the early 1960s that seats about 2000 and is a little on the dry side acoustically. Generally I agree with what you're saying however true fff peaks will break 95db from my seat half way back.
