Bryston BDA 1 break in time
0 Members and 1 Guest are viewing this topic. Read 1637 times.
robb
« on: 21 May 2009, 03:29 pm »
Hello
Just wondering what the typical break in time for the Bryston bda-1 normally is and  what can be expected when it is?
I just hooked one up to my system and straight out of the box the bass is a bit wooly and ill-defined and the soundstage is restricted, compared to my well-used Theta from 1999.
Any thoughts will be appreciated.
Rob
  • The Demo is Everything!
    • http://www.bryston.com
Re: Bryston BDA 1 break in time
« Reply #1 on: 21 May 2009, 03:36 pm »
Hello
Rob
Hi Rob,
I would say give it a day or so. It sounds from your discription though like a major negative change and I doubt that break in would affect the sound that much.
james
werd
« Reply #2 on: 21 May 2009, 05:15 pm »
Hello
Rob
Hi Rob
Just wait it out... the bda is very neutral and can be a bit of a shock at first. it will sort itself out. Listen to it for about a month and then go back to the theta and you see what i am talking about.
robb
Re: Bryston BDA 1 break in time--update
« Reply #3 on: 26 May 2009, 02:12 am »
Thanks for the input.
But after about 18 hours of use, the sound of the bda-1 has greatly improved.  Bottom is hefty, solid and taut, defined; highs have sweetened considerably; soundstage is now deep and wide.
So I guess I answered my own question;  the bryston bda-1 definitely needs about 18 hours beak-in time.
rob
Stu Pitt
« Reply #4 on: 26 May 2009, 02:41 am »
I don't know if its so much break in as it is warm up.  Any digital component I've had - CDP or DAC - sounded better after being powered on for about 3-4 days.  After being turned off for a day or more, they've always sounded thin and have rolled off highs and lows.  At least to my ears anyway.  From my experience, its more obvious and takes a little longer in digital gear than amps/pre-amps.
I don't own a BDA-1 or a BCD-1, so take this as you will.  I wish more of these things had stand-by switches on them to save a bit on energy, yet keep 'em warm.  Amps especially.  If my NAD gear had a standby mode, why can't my current gear?  No offense to the Bryston engineers.
robb
« Reply #5 on: 27 May 2009, 01:37 am »
Stu
You may be right--my Theta Pro-Basic IIIA manual says it requires 4 days of warm up to sound its best.  There is a power switch on the front but it only turns off the digital section; the analog section is always powered on.
rob
