0 Members and 1 Guest are viewing this topic. Read 15524 times.
A good start, and once you mount those on baffles, and raise them up to ear height, I will be interested to hear your thoughts.
I was able to lay my hands on a pair of Hemp 8FR about 1 year ago, they sound quite good, however there is a minor fault that is it displays a serious spike(bump, > 3db) at around 8Khz. I suggest you check it out. They may have solved this problem by now.
The shout moderates some after 100 or so hours of use. I ended up cutting out two small circles of felt and gluing them to the dust cap with Elmer's spray glue, it is supposed to dry tacky instead of hard. I cut the felt so it did not touch any part of the whizzer cone.
The driver's qts is to low to produce much bass in an open baffle.
That's a Selenium 15 under it.
The FR8 certainly needs bass support on open baffle. No matter what baffle style I tried it still needed bass support.But as an OB midrange, it's very nice.
OB is all about the addition of the back wave in my experience. I don't really understand why your choking it with the felt.I feel that the "openness" of the sound needs the back of the driver to be able to breath.Just my thoughts.
Will the final versions have to remain too close to the wall?
I've found with mine that they like to have some distance from the back of the speaker to the wall in order to sound they're best. Mine sit about 130cm from the wall. The rears do, however, fire into corner bass traps which are more like 90cm away. It would be good to experiment with placement as much as practicle.
Now the biggest problem is the shout. It's not gone and I'm afraid it will never be, unless i filter it.
Ask panomaniac how his FR8s shout without the Seleniums below. Me personally would not dare to judge the "shoutiness" of a midrange driver without a decent bass fundament. Have you ever listened to your Linns with the woofers switched off?
BTW: Your cardboard baffles may be "rigid" for higher frequencies. But they are a weak and bending support below ~ 500 Hz. All your low frequency experience could be meaningless unless you have more rigid baffles.
Yes, I have. Mids (400-4.5k) only powered by the F3, when I was checking/burnign it. No shout. ...I can do another test tomorrow, but i'm 99% sure that they dont shout....But I think the Hemps need a notch filter, period.
