AudioCircle Logo - RightAudioCircle Logo - Left
Pages: [1] 2 3   Go Down
Author Topic: Elsinore DIY Speaker Build  (Read 2200 times)
0 Members and 1 Guest are viewing this topic.
« on: 7 May 2009, 01:55 AM »
Hello all,
I thought I might post some pictures from my "work in progress" build of the Elsinores.  These speakers are designed by Joe Rasmussen who is a big contributor over on diyaudio.com and it looked like a fun/interesting project to do.  The link to the plans, design goals, and other project details can be found at http://www.customanalogue.com/elsinore/elsinore_index.htm
First, 1 inch (25mm) thick mdf is hard to come by, so I had to buy several sheets of 1/2" (12.5mm) MDF from Home Depot and glue them together.
Lots of Glue:
Lots of Clamps!
Lots of clamps and a great set of tools courtesy of ThomasW (who is an active poster and a moderator over on Hometheaterguide).  The tools are great, but Thomas' guidance and expertise was by far the most valuable part of this whole project.
Next day, time to start cutting them to size, courtesy of these saws:
and
and the first pass:
Now, time to start drafting!!  This is where Thomas' experience REALLY kicks in, I would have severely screwed this up if I'd been doing it on my own, but with his guidance it was a snap:
Pic of the workspace in Thomas' basement:
Ready for cutouts:
Time to start cutting and routing:
Main Braces are done!
Front panel has bottom sub-panel attached:
Rear View:
Main Front Panel with sub panels attached and routed:
Rear Vew:
Next up, assembly, wiring, and acoustic stuffing.  Stay tuned....
« Last Edit: 7 May 2009, 05:06 PM by Tyson »
Headphones Lawton Audio (Denon) LA-2000 Jurrah Wood
Headphone amp Singlepower Supra SE
Speakers Ella DIY Speakers actively Triamped w/mgalusha modded DCX2496
Speaker Amps VTA ST70 stereo KT88 tube amp (mids), VTA ST70 stereo KT66 tube amp (tweeters), Audio-gd C1 fully differential balanced SS amp (Bass Woofers)
Preamp Mapletree 2A SE - 12SN7 tubed preamp
Source MHDT Havana NOS Tube DAC
My Single Malt Scotch Journey
Recommended Audiophile Classical Music Recordings
Hogg
Re: Elsinore DIY Speaker Build
« Reply #1 on: 7 May 2009, 02:31 AM »
The project looks great so far :thumb:.  Did you order the parts from Custom Analogue Audio as well?  What do you plan to drive the speakers with?  Keep us informed on your project :green:
        Jim
"Without music, life would be a mistake"      Friedrich Nietzsche
« Reply #2 on: 7 May 2009, 03:03 AM »
At first I'll be running it with my DCX 2496 active crossover, mimicing the crossover point and slopes of the passive crossover.  This should give me a good idea of the general quality of the drivers, box alignment, and overall sound.  Assuming it sounds good (and I've got no reason to think it won't), then I'll build the passive crossover and do the veneer work.
Rocket
« Reply #3 on: 7 May 2009, 08:49 AM »
Hi Tyson,
What made you chose this particular design?  What speaker/tweeters are you using in the design?
Regards
Rod
Rocket
System:  Pioneer PDS 507 (modifed), perpetual technologies p1a/p3a modwright level 2, N.E.W. P3 tube preamp, Son of Ampzilla, Nuforce S 9 and Salk Sound HT2
Soundsgreat
  • Registered
« Reply #4 on: 7 May 2009, 08:51 AM »
Hi,
Very interesting and impressive !!
Will be keeping a close watch on this thread  :wink:! Could you please mention the drivers that you'll be using in this project !
Regards.
My DIY Efforts !!
Checkout and give me a feedback or two !!
The Anaconda l The DIY Speaker CableMy DIY Towers l The Almighty Subwoofer l DIY Dome Tweeter l MY DIY Interconnect
« Reply #5 on: 7 May 2009, 02:49 PM »
The drivers are peerless HDS 810921 tweeter:
and the peerless HDS 830875 Nomex woofer (Four per side):
The top woofers are run full range in an MTM configuration, with the tweeter recessed to time and phase align it, and the bottom 2 woofers are there to "fill in" the bass at 400hz and below.  This actually compensates (acoustically) for the normal 6db baffle step loss that every speaker has once the wavelength becomes larger than the width of the baffle.
Net result, from 400hz on up, it acts as a point source, and below 400hz it acts as a line source, with zero loss of efficiency from baffle step loss/compensation.  Pretty impressive!
« Reply #6 on: 7 May 2009, 02:53 PM »
Here is a pic from Joe's site, so you can see what the end result looks like.
Mine will be a light wood, such as birch or bird's eye maple:
Here's a skeleton view of the construction:
Carl V
  • Registered
« Reply #7 on: 7 May 2009, 04:14 PM »
Nice design
Nice drivers....looks to be a nice project
Thomas is a Moderator on HTG Home Theater Guide
HTT Home Theater Talk is no longer around.  Thomas
was a contributor there.
Justice John Marshall Harlan: "... the State has no right to cleanse public debate to the point where it is grammatically palatable to the most squeamish among us."
rajacat
  • Registered+
  • Washington State
« Reply #8 on: 7 May 2009, 04:45 PM »
Tyson,
Is that felt surrounding the tweeter?
-Roy
Thorens TD125 MKII
Felix>Acopian power supply>Bolder SB3>modded Mhdt Constantine w/Felix
Van Alstine T7 pre> restored/modified Heathkit W5m monoblocks
Omega Hemp Bipoles V1; ACI Titan sub
Sony XDR F1-HD Digital tuner
« Reply #9 on: 7 May 2009, 05:05 PM »
Yes, the tweeter is recessed almost an inch back into the cabinet to align it with the acoustic center of the woofers, and then 2 layers of felt with different sized cutouts are used to slightly horn-load it, and also to eliminate edge diffraction.  Here's a close up:
and
Pez
  • Packaged and ready for distribution
  • Gallery
« Reply #10 on: 7 May 2009, 05:19 PM »
Wow, so far so good, must be Thomas doing most of the cutting.  :P
Pez..... the dispenser of truth.
System:
Source- Sony XA-777es
Amplification- Response Audio Bella Extreme 3205 special modded for Bolder Cables RMAF 2006, TomS modified DCX 2496, Stock QSC dca 1222 amp pro amp,
Speakers- VMPS RM40s actively crossed bass section, actively crossed panels, passively crossed FST tweet
Cabling, Bolder Nitro, speaker cable is custom Kimber Kable 1 of 3 in existence for mids/highs. Bolder M80 cabling for bass.
rajacat
  • Registered+
  • Washington State
« Reply #11 on: 7 May 2009, 05:33 PM »
Wow, huge project! It must be nice to have professional grade cabinet tools available. Lookin' good. :thumb:
Hmmm...I guess I'll try the felt on my speakers. I wonder if a Scotch Brite pad would do :scratch: :)? Thanks for the pics.
-Roy
Thorens TD125 MKII
Pez
  • Gallery
« Reply #12 on: 7 May 2009, 06:10 PM »
What's up with the routed out part where the tweeter goes? Why no hole there?
System:
Bob in St. Louis
  • Come on in, have a seat.
  • Gallery
« Reply #13 on: 7 May 2009, 06:22 PM »
Is this the same ThomasW that the "main dude" on the Cult of the Infinite Baffled site?
Nice build Tyson, looks like fun!
Bob
DCX2496 Full active 5.1 Open Baffle Home Theater w/ Hawthorne Audio drivers ** (4)15" Hawthorne Augies in IB Beta testing ** Bolder modded Squeezebox3 ** 1.5TB USB external RAID1 ** a bunch of other DIY stuff to make all this crap work together.
Pictures of my toys - Home Theater System - Two Channel System
Member of the Fellowship of Audio Artists...... ;)
Email = BobInStLouis@att{dot}net
JoshK
« Reply #14 on: 7 May 2009, 08:28 PM »
Bob
Indeed, same ThomasW.
« Reply #15 on: 8 May 2009, 03:27 AM »
Nah, routing recess was done first, we'll use a round saw to cut out that middle part.
mgalusha
« Reply #16 on: 8 May 2009, 01:16 PM »
Nice. I had wondered where you were going to build these and I recognized Thomas shop in the first picture. Yeah, I am that sick. :)
Looking forward to hearing these.
mike
Mike Galusha
2ch|gallery|EnjoyTheMusic|custom builds/mods (a few)
Pez
  • Gallery
« Reply #17 on: 8 May 2009, 09:20 PM »
Tyson,
Is it too late to suggest a design change?
The latest tribute to H1N1 perhaps...
System:
JoshK
« Reply #18 on: 9 May 2009, 12:15 AM »
Tyson,
We are back to nOrh again?  :icon_twisted:
« Reply #19 on: 9 May 2009, 02:10 AM »
The 4.0's are still one of the few pieces of audio gear I regret selling, to this day.
Pages: [1] 2 3   Go Up
« previous next »
Page created in 0.19 seconds with 72 queries.
