0 Members and 1 Guest are viewing this topic. Read 8590 times.
Hello brj in James Bongiorno's info on his web site the centre channel is paramount in importance all speakers should be alike... and where available if desired the centre speaker can be of higher spec.I believe J Casler has documented his experiments with just such an application using the same family of speakers.The centre channel needs to be at least equal to l&r spkrs not inferior.Cheers Russ R
paramount
Earl Geddes/Duke LeJeune's multi-sub philosophy (three subs mimimum; Duke employs four) w/ which I've become familiar is so far superior to any so-called fullrange speaker that I now view fullrange speakers as a quaint anachronism, a relic from the past. In fact this sub philosophy is the single greatest thing I've learned in audio. The worse the room's modes the larger is the audible advantage. But IMO the single best thing about it is that it is the most efficient method to reproduce the acoustic effect of a large commercial space in a domestic environment. Further, this phenomena (large space bass effect) is the single most audible difference separating live music sound from reproduced sound. Yes, more than any component or speaker swap (once you've attained at least a bare minimum quality).
brjYes, I definitely agree w/ the accessories moniker; should have posted it there originally, sorry!I heard the Trinaural w/ the largest floorstander mixed w/ two of the smallest standmounts from the same maker. But a sub was employed because the largest floorstander was built to use only w/ a sub & its bass cutoff was about equal to the standmounts.I'd bet your scenario would be fine. But I must state for the record here that Earl Geddes/Duke LeJeune's multi-sub philosophy (three subs mimimum; Duke employs four) w/ which I've become familiar is so far superior to any so-called fullrange speaker that I now veiw fullrange speakers as a quaint anachronism, a relic from the past. In fact this sub philosophy is the single greatest thing I've learned in audio. The worse the room's modes the larger is the audible advantage. But IMO the single best thing about it is that it is the most efficient method to reproduce the acoustic effect of a large commercial space in a domestic environment. Further, this phenomena (large space bass effect) is the single most audible difference separating live music sound from reproduced sound. Yes, more than any component or speaker swap (once you've attained at least a bare minimum quality).
