0 Members and 1 Guest are viewing this topic. Read 27072 times.
It's definitely not the former, being as you have an external drive.
I don't know if storing artwork is your problem, but my understanding on how and where artwork is stored is: If the artwork is downloaded automatically from the Internet while ripping a CD, the artwork is stored in the iTunes database on your OS/programs/user profile drive. However, if you edit the Song Info and simply cut and re-paste the artwork on the Artwork tab or if you drag artwork in, it will instead be stored within the song file (filetype permitting, i.e. .WAV artwork will always be stored in the iTunes database.) Steve
Every time iTunes is started with the external disconnected, iTunes will default to your local HD, even if you've set the path to the external drive. That said, and from what you're describing, it sounds like the library path has defaulted to the internal drive. ITunes is trying to copy your library over from the external HD because you've enabled the option to keep your library organized in Preferences (which is what you should do), and your library location is local. You're filling up your local HD. You need to delete those files on your local HD, reset your library path to the external (with the external plugged in), and then use Add to library to rebuild the database file. This is not an artwork issue.
My SSD in the mini has 66GB available. I've deleted what was on it under users > my name > Music > iTunes
Thanks Steve.I would gladly call someone for help at this point....anyone?
Thanks Crimson.Is the music folder normally pointed like this?desktop > user > myname > music > itunesor is it usually volume > itunes > musicMy problem now is that I can't remember how I had the directory set.This has turned out to be such a mess as I deleted my HD last night and used the backup. Well turns out that I'm about 21 albums short somehow. I want to
