0 Members and 1 Guest are viewing this topic. Read 88499 times.
HI Mark,Got no say what gets shoved around let alone by how much!The "cleaner lady" is the missus. Lucky she doesn't get to look at this site or I would be shot with a reference like that I would be shot. It was suggested that I do the cleaning if I don't anything moved. As for a speaker locating texta mark on the floor, I don't think it would be a good idea here for health reasons.Interestingly, while re-establishing the placement for the speakers using the bass to locate "the spot" I noticed that the voice coming from the R/H speaker was suddenly harsh. The L/H speaker sounded sweet. I swapped the speakers over and the harshness from the R/H position still persisted. I noticed that a lounge chair in the corner adjacent to the R/H speaker had been moved some 18" from the wall closer to the speaker. Shoved it back to its original position and the harshness has vanished. I have taken a few measurements of the positioning of the speakers for future reference.Cheers,Laurie
Steve,You're right .. I need to hear it and/or play with it for myself as I'm not quite "getting" it on paper. Ignoring reflections, rooms only effect frequencies below 200Hz. So, I can understand the equalisation of pressure under 200Hz, by making speaker positions asymmetrical, could offset room effects and equalise pressure at the listener. But this will only be at various points of the wavelength of various frequencies. As each frequency has a different wavelength, the equalisation for each occurs at different distances from the front wall. The ideal result is to find a speaker position where there are no significant peaks or nulls ...perhaps this is what provides the "smooth" response you are hearing? I think this is what I have achieved in the past via extensive measurement, using third octave pink noise (closer to how we hear than single frequency tones). I must admit that I did keep the speakers symmetrical but I did achieve very flat results. But, the frequencies above 200Hz are not effected by the room and if they are not equidistant from the listener, then ... surely ... the difference in amplitude must pull them toward the nearest speaker. Oi ... my brain hurts
Steve,I STILL HAVE THE PIECE OF PAPER. I TREASURE IT!! Hugh
Quote from: AKSA on 16 Mar 2009, 04:11 amSteve,I STILL HAVE THE PIECE OF PAPER. I TREASURE IT!! HughHugh,Never has a piece of paper been so valuable in your house!!I'll have some writing in the making that will be posted a bit later.Steve
Thanks Dave, nice info. I also enjoyed reading your Agon review. I met Guido at RMAF 07, nice guy, very serious audiophile.The lifting step is for adjusting the vertical position minutely, correct? How does it "set itself?" That's what I don't get. Thanks
Quote from: richidoo on 17 Mar 2009, 09:03 pmThanks Dave, nice info. I also enjoyed reading your Agon review. I met Guido at RMAF 07, nice guy, very serious audiophile.The lifting step is for adjusting the vertical position minutely, correct? How does it "set itself?" That's what I don't get. ThanksThanks for you kind words Rich.No, the lifting step fine tunes the front/back/sideways placement. It'll only move a fraction of an inch, like between a 32d and a quarter. If you were sitting out front when it's done you'd hear it. You feel it when your the one doing it.Dave
Oh, now I know who Guido is. I've seen him at RMAF every year.
Hi All,I heard the "set up" VSonic speakers at Hugh's today. My first impression was a conciderable increase in the width and depth of the sound stage and imaging virtually from one wall to the other of the room. In summary, there is an overall improvement in presentation. But Hugh & I noticed that the bass was much more powerfull and had a fuller sound within "the triangle" than any other listening position in the room.When I returned home I turned on my VSonics without the woofer. I listened for a while while slowly moving the right speaker by very small increments along with the toe in of both speakers. Now I feel the resultant sound is possibly as good as it gets from the now much wider listening area. However, I have noticed that the bass is diminished within the triangle and conversely to Hugh's set up the bass is better outside the triangle. I don't know what is exactly going on here but obviously the room and content placement has a large influence.I later turned on the woofer (which is balanced to suit the VSonics) and of course introduced extra punch and slam to the music to about live performance levels. I noticed that although the wooferr is positioned to the left of centre between the main speakers there was a decided improvement in imaging of the bass. Now with a good recording of a double bass playing the imaging is such that you can actually place the string that had been plucked not only the impact of a note but the decay too.I have been playing around with speakers longer than I can remember but the Master Set procedure of speaker alignment is a revelation.Yep, I'm glad that this thread is going Steve.Laurie
