0 Members and 1 Guest are viewing this topic. Read 88482 times.
Steve-I use the Cardas formula as a starting point and move the speakers around from there. My room is just a bit smaller than Hugh's (138" x 210").My speakers have rear firing ports. I've found that they sound, image and measure better further out from the rear wall. The sweet is not just a few inches.BTW- Sumiko trains their dealers on the Master Set methodology. Here's a review:http://forum.audiogon.com/cgi-bin/fr.pl?rspkr&1197744079The Wilson Audio set up procedure also uses a similar methodology."With Master Set you can sit anywhere in the room with same sound."If you're sitting a few feet directly in front of either speaker, the image/soundstage is the same as sitting between the speakers?Dan
Dan,Dave Stephens wrote a good review of Master Set. I've corresponded with him for awhile. In fact he is one of those who helped me in my DIY efforts at doing Master Set. Dave is a customer and friend of the Sumiko dealer in Denver, Rod Tomsen, who I have known for 15 years, and who has helped me the most in my DIY Master Set. If you search the audiogon forums for "Master Set" or "Iron Chef" you'll get most of what's been written on Master Set other that what I have written here on AC. At some point in time, Rod Tomsen may write an article for one of the audio magazines, which would be good. Rod is probably the number one practictioner of Master Set of all the Sumiko dealers. He does not sell a set of speakers without home delivery and Master Set setup, and the customer pays extra for this. You get a perfect setup by the master.With Master Set, the sound is pretty much the same, no matter where you sit. The sound always stays in the center and does not move with you. If you move way to the side like to the right of the right speaker or left of the left speaker, the perspective to the centered sound will change a bit. It's analogous to moving seats at a symphony from the right section to the left section to the middle section. As long as the speakers are pressurizing the room equally the sound always stays the same. What happens when the speakers are even slightly different is that you always then tend to hear the louder speaker, especially if you move to that side, even just a little.In my set up here, I have the choice of a seat perpendicular to the right speaker, a couch seat way to the left of the left speaker, or a moveable seat that I can put in the middle. I no longer sit in the middle position as the right seat is comfortable and the sound is the same. BTW, my speakers have a rear port, and it presents no problems whatsoever.At Hugh's yesterday, we had a seat in the middle, a seat to the right of the right speaker, and a seat to the left of the left speaker. We all moved around and agreed that it was the same in each seat. Hugh and Marty were amazed. I knew it would be that way if I had gotten it correct.Master Set is not really the only way to get this equallization of speaker sound pressurization into the room, it's just one way. I really don't know any other way, so I use this one. The more I do it, the better I get at it, it's a long learning curve.Steve
At your convenience and pleasure Steve, I would very much like for you to indulge us in your ideas and understanding about Master Set. The subtleties are always the hard part to grasp. Your experience doing it a few times is valuable to us who are learning to do it. ThanksRich
Steve-The off axis performance you're getting maybe acceptable for listening to studio recordings, but to recreate the illusion of a soundstage (if it's been captured on a recording) requires that your ears receive direct sound from the speakers before multiple room reflections come into play. This is why many people listen in the nearfield set ups.BTW- I'd love to see a picture of yours and Hugh's set up.Dan
Master Set is a close to rear wall set, rather than a set up way out in the room.Steve
...Room gain will give the closer speaker slightly more sound pressure to fill the slightly larger area.When the sound pressure is equal in both parts of the room, then the sound will sum perfectly in the middle creating a single source of sound. And because of the equal sound pressure levels anywhere in the room, the sound will be virtually the same anywhere in the room....
...The long wall in the room works best. Remember, the room is invisibly divided by the two speakers. Dividing along the long wall gives a more square shape and the sound will more evenly fill the space without reflecting off the walls. Dividing along the short wall gives a long narrow shape that will be very subject to wall reflections...
...The equal sound pressure throughout the room usually negates any need for room treatment or correction. Experience will tell you about this, once you listen. I've seen little to no correction in the Master Set rooms that were done professionally...
...Master Set is a close to rear wall set, rather than a set up way out in the room...
Hi Hugh,The cleaner lady moved the speakers this morning and now they have to be reset. And I can'r remember EXACTLY where they were positioned so I have to go through the Master Set process again.So Hugh, please mark the position of your speakers with a texta should they be moved ever so slightly before I have a listen.Cheers,Laurie
