0 Members and 1 Guest are viewing this topic. Read 33184 times.
This may be OT, but what are the advantages of upgrading a motor controller vs upgrading a motor?
As far as new stock motors are concerned, fuggedaboudit.
G'day Thom,Appreciate you dropping by, quick question, what motor would you recommend looking at?And your thoughts regard a Garrard 301?Thanks,Drew
Tough call, Drew. I haven't researched the idler drive units, so I can't really comment intelligently. If I were in your position (since this is a one-off and not something that requires new production stock quantities), I'd start by researching motors by Papst. Many of them are quite large however, so fitting them inboard will be a challenge. In new stock, about your only choice is the Airpax (Phillips/Premotec) used in the various Brittish belt-drive rigs. This would be a fall-back scenario.Cheers,Thom @ Galibier
