0 Members and 1 Guest are viewing this topic. Read 56305 times.
I ask a 'few' questions on here-because the people who answer them are knowledgeable and provide helpful answers. To the question: 300B's are expensive. Around $200 a pair give or take (mostly TAKE). Do these tubes last longer than, say a similarly rated KT-88? The 40 watt anode is nice- but might it be more cost effective to run 6L6's in single ended parallel, triode mode?What is the cost/benefit ratio in technical terms (not sonics) vs pentodes. I say this because I believe a pentode can be made to sound just as good.
Hi Blair,Just to get those numbers right, 300B's start at around $200 a pair and for NOS WE 300B's the price is getting up over $2k, decent new production 300B tubes range from around $300 to $900 a pair. ...
Now if you can build a 50 watt 300B SET, you will rule the audio world Cheers,Ian
