0 Members and 1 Guest are viewing this topic. Read 9833 times.
Hi Andy,Yes all set. I may have to come straight from work but if I can look after them OK during the day, I may bring some vinyl as well as a CD track or two. Hugh, that 'synergy' (or at least 'compatibility') aspect between components I find very real. I'm just so happy that my speakers and CD player go so well with your kit though at least we knew they (Soraya and GK1) worked well together and nothing was selected without a lot of listening.Incidentally, every change/improvement I've made over the years has relied on a lot on such patient listening and then they have pretty much been incremental in degree. I suspect that this may be part of the problem with Theo's DEQX set up. It is a system capable of implementing complex/compound variations at the press of a button and I find myself rather bewildered and without an adequate aural reference base very quickly after a few rapid changes. Even for a single change, it often takes me quite a while to come to grips with all aspects of it - hours, days or even longer. That's why I tend to only change one thing at a time if possible on my system and why I struggle with coming to grips with mass change such as a DEQX can bring.
Andy,Like Arni, I'M BACK.....Can I come tomorrow night, please?Hugh
And Hugh, considering your new little treasures I heard briefly before going to Andy's, you deserve another holiday as a reward! All you AKSAfiles will not know what hit you. Wow is it good!T
That sound stage...... I really think the Maggies sing in your listening room, something to do with the gable angle, too.
A new product line, nothing more......Cheers,Hugh
Hi All,What a wonderful system you have Andy. It really makes vinyl live and the Cd's were superb too! I would kill for your dedicated "listening room". A lot of good design work there. Your Maggies are the best I have ever heard and the slam and definition of the bass surprised me, it really did! I was amazed the way the sound attenuation tubes changed the sound stage, bringing it right forward.Regards to all,Laurie
